Whinning Noise - CVT?
This happens with my 2012 as well. The dealer did the tcm update and they said that solved it but it still does it. I am taking it back to get some backordered parts installed so I will ask again then. If I can get a good answer I will post it.
That doesn't sound good and would be very annoying. I'd send the links to your dealer/ Suzuki.
It reminds me of the noise you get with straight cut timing gears on older engines (like in this clip ). Obviously absolutely nothing to do with your noise though.
It's interesting the number of hits on Youtube when you search for "cvt whining"
eg:
They both sound like the noise you're getting.
eg:
The last link in Murcod's last post above is very interesting. The car is in park , so in theory, the trans' belt is not rotating (or is it?) and the pitch of the whine varies w/ throttle change. Input shaft bearing? Pump noise? Is the pump even pushing fluid in Park? Too many unknowns w/ these damn CVTs. I'm really starting to believe that some folks' really low MPG numbers are related to a CVT issue of some sort. Almost as if there's a slippage occurring as in a conventional trans. IDK
Probably to help insolate the problem try putting it in each gear manually then try it. Note if only individual gear or all.
