I have water sloshing around when I make a left turn. I do believe this to be a result of the AC drain tube being clogged. Could someone tell me where to locate said AC drain tube?
I have cleaned out the air filter and will replace it tonight, just need to know where the tube is so I can clean it out.
AC Drain Tube
I don't know exactly where it is, but these aren't hard to find if you're under the car and looking close to the firewall. When you run your AC, is there no water that drips from under the car and makes a puddle?
The diagram is showing that the drain tube is behind the front axle (close to the transmission). You will have to get under the car and probably remove the underbody covers to see and access it adequately.
The axle on the right side.KuroNekko wrote:The diagram is showing that the drain tube is behind the front axle (close to the transmission). You will have to get under the car and probably remove the underbody covers to see and access it adequately.
So I found it after I took it to the Mechanic. If anyone is interested. It is on the driver's side. Just above the power steering pump. There are two bolts on the bottom side about where the driver sits and it is just above the cylinder for the power steering pump. Mine had about 2 litres of water in it. All is well now.
