P2227
speedsterz
After multiple trips to the dealer and other mechanics I'm doing what I should have done first, checked with my fellow Kizzy drivers...I've been having some evap issues, the code culprit is P2227. So far what's been replaced is:
  • carbon canister (twice)
    canister purge solenoid
    leak pipe
    leak pump
    cleaned the MAF sensor
Car ran great for 5 blocks and then CE light came on AGAIN!
It's been months with this issue. Additionally, whenever the CE comes on it also triggers the traction control, hill hold, and ESP to shut down.
My Kizzy is pretty much stock with the exception of a drop in K&N filter.
Any thoughts?
Thanks!
Mike
2010 Suzuki Kizashi GTS - Platinum Silver
"Knowing is not enough, we must apply. Willing is not enough, we must do."
speedsterz wrote:After multiple trips to the dealer and other mechanics I'm doing what I should have done first, checked with my fellow Kizzy drivers...I've been having some evap issues, the code culprit is P2227. So far what's been replaced is:
    leak pipe
    leak pump
I have no idea what this desperate flailing about is supposed to do with the Barometric Pressure Sensor which is built into the ECM. Sounds as if they're playing parts darts, throwing things at it in the hope that they'll accidentally hit something.
The service manual goes straight to "replace the ECM". That's very expensive and very unlikely to be the problem, but it's something to keep in mind. The BPS inside the ECM senses ambient barometric pressure. The ECM also takes the MAF and IAT sensor readings, combines them with the throttle position and power delivery numbers and tries to calculate what the barometric pressure must be. If these two readings are drastically different, then it throws a 2227. If the ECM receives a bad report from any of these then the calculations will be off, I'd suspect a bad electrical connection somewhere. The logical thing to do is to hook up an OBD2 reader with a logging function, drive the car until the light goes on, and then review the output from each sensor to see if something glitched.
This drives me absolutely insane, if the car has a problem that's pretty much the only time I want all of this crap to work. When my car is in good working condition, I'd rather have full control without a bunch of "Big Brother" interference. If there's some kind of failure, low tire pressure being a good example, I can see some value in the computer trying to save me. But no, that's exactly when they disable all the nannys. :facepalm:
speedsterz
Woodie, appreciate the details...knowledge is power.
I took it in to the dealer many moons ago right before the warranty expired which explains why they played dumb as I'm sure the last thing they wanted to do was replace an ECM under warranty work.
Thanks again!!
I'll update post post shop work
    leak pipe
    leak pump
One has to ask the logical question....who, exactly, is coding the ECMs and all other nanny systems in vehicles these days? This is an example of why I will strongly, and forever, resist vehicles that try to drive for me. Are you listening GOOGLE? Exception handling programming in automation is extremely time consuming and even more costly simply because of the near infinite amount of testing that MUST be done in order to PREVENT these types of "glitches" from happening, ever. Perfect world programming is just that. Easy, fast and cheap to do. Why is it that my Heep has had (2) TCM flash 'upgrades' in 2 years and 11k miles to fix supposed problems only to make the thing shift worse, and lose fuel efficiency, compared to the original factory flash did? Now they say it needs an ECM flash update as well...pass. It ain't broke and runs fine. It's not like this trans/engine combo is brand new...it's been around for a 2 full years prior to my model year. Well, that there would be the software version of "parts darts".
