Does the 2013 SX model fits 16in winter tires?
Kiki
Hey all,
Im about to buy and install winter tires for the car. I saw some people talking about installing 16in tires but other sources I saw only mention 18in ones as being the norm. Which one is correct? This is for the 2013 model. Thanks!
To start, the base model Kizashi came with 16 inch wheels from model year 2010 to 2012. Which trim and model year you have determines whether you have factory 16, 17, or 18 inch wheels.
Also, a lot of talk about 16 inch wheels for winter tires comes from people who have a totally separate set of winter wheels and tires. Basically, they purchased additional wheels and tires not original to their specific Kizashi so they can swap out their Summer wheels and tires quickly and easily for their Winter set. Because they needed to get wheels in addition to winter tires for this, they got wheels of their own choosing. Many people get 16 inch wheels for the winter because they are not only cheaper, the smaller size makes for better snow traction. A 16 inch tire of the same type will handle better on snow than a bigger and wider 18 inch tire. This is because the narrower tire can sink in a bit more to grip snow rather than roll on top. It's a bit counterintuitive and opposite from dry traction but just a reality of snow traction.
So again, the Kizashi came with different sizes based on trim and model year but for a winter set, it makes sense for many to get 16 inch wheels and tires.
I believe I used the sx4 16" for our winter kizashi set, which I believe were just a bit narrower than the Kizashi 16". They've worked great.
Tom Kizzie
Does anyone on this forum tried 15 inch yet??? I have 15 inch very light ATS DTC wheels (used in swift cup racing) which i consider to use for my Kizashi (first selling my 17 inch)
kizashi 6mt black
15" wont clear front Kizashi calipers. Toyota uses the same bolt pattern and hub center on many of there models so there is no shortage of properly fitting 16".
Tom Kizzie
Thnx !
yes there are a lot of wheels. And using centering rings is also no problem if another car has a bigger hub or its just an aftermarket wheel (mostly 73milimeter )
kizashi 6mt black
