Rough Idle and hard brakes
car has been running perfect, yesterday, started it hot and got a very rough idle, almost stalled and brake pedal got harder (not complete loss of power, but noticeably harder) sounds like a vacuum leak to me, but can find one anywhere, line from brake booster to intake is perfect, recently cleaned throttle body and maf, installed new plugs, could use some ideas where to start troubleshooting.....searched forum and couldn't find anything related to both problems at the same time
Symptoms of booster leaks are higher than expected fuel consumption , cold start and rough idle issues, if you know what to listen for, you can actually hear the booster leaking vacuum from under the dash. It may sound like a fan running under the dash and may change in volume as you apply the brakes while stopped or the hissing noise may diminish when accelerating normally from a stop.
Try pinching off hose to vac booster. If there is a change then G13b has nailed it. If still no change then maybe fuel mixture is way off caused by debris on maf . Remove and spray with carb cleaner. Another possibility is vvti actuator stuck. I have yet to see this problem on a Kizashi but plenty of times on Toyota, lightly tap around mounting bolt with engine running and listen for change . One last area is canister purge control that possibly is stuck open.
- SAEED_KIZZY
if your car is CVT check CVT oil.Contaminated CVT oil may also cause engine rough idle specially in hot weather.
