Kizashi instrument cluster
nickoloza
Hello.
Do you guys know how can I remove instrument cluster? There's some dirt inside of the speedometer glass and want to clean from inside, should I also remove the center dashboard to get to it?
Do you happen to have some video or instruction of how to remove it? Don't want to break something.
Thanks a lot in advance.
hello.
unfortunately, it's not an easy task but can be done I have done it once.
here is the instruction from the service manual
IP.pdf
(4.79 MiB) Downloaded 369 times
nickoloza
Hello.
Thanks a lot, will look through it!
SAEED_KIZZY wrote: Sun Feb 27, 2022 7:44 am hello.
IP.pdf
