A/C Compressor
nickoloza
Hey guys.
Hope you are all doing well.
My A/C compressor died, needs replacement. Do you know, at first, if it can be repaired or should I buy a new one? Have you had this kind of experience before?
Also, is that part interchangeable, maybe another car's fits to Kizashi.
Thank you in advance.
I have seen the magnet clutch winding failure maybe 6 times. The compressor pulley bearing twice. The front clutch plate with the 3 circular cushions failure once. I have not seen the actual compressor portion fail yet and I see alot of these Kizashi's. i couldnt find any one to sell the complete clutch unit but I did find the clutch winding unit and it fits and works perfect. This I change without compressor removal or discharge. It was sketchy to get and i ordered multiples at the time . I can sell you one if you would like $60+ shipping . I will through in a front plate for $10 I do not have the pulley/bearing asm.
