Debadging?
- FrankoLaMoya
Hey Remav..interesting what you done with the front S and the rear one as well! I always wanted to remove the S shape in the front, but it is not possible (the S will still show after the chrome S is removed)
I've tested the front badge with an unsuspecting brother & after pointing it out to him he said that he had really thought it was behind the grille. I thought I'd try to keep the theme and obfuscate the one on the rear better. Here is the result which I'm really liking, (but still needs a little clean-up):FrankoLaMoya wrote:Hey Remav..interesting what you done with the front S and the rear one as well! I always wanted to remove the S shape in the front, but it is not possible (the S will still show after the chrome S is removed)
- R-Rebadge.jpg (158.61 KiB) Viewed 4559 times
- FrankoLaMoya
Definitely interesting...at least it does not necessarily look like a Suzuki emblem. I will probably try to do mine next summer. I will remove the front S...buy another grill (same pattern and size, maybe not a Kizashi one) and try to cut the grill to fit it like it would be a full grill, but with a black S in the back which will not really show..
