Found out why my Kizashi was a bit lethargic
golftango
I've always felt my Kizashi was a bit lethargic, really needed to wind the engine out for decent response. My hypothesis is that it wasn't breathing well. I decided to look at the stock intake for obvious issues, cracks, blockage etc. Then I noticed that the fresh air inlet duct gets air from between the hood lip and grille (#19 below.) There should be a good gap there, but not on my Kizashi because "Suzuki bug-defector/hood guard". It drastically reduces the amount of air that gets to the intake.
So I removed it and I don't know if it's a placebo effect but it definitely feels peppier. :?: :drive:
2019 Kia Optima EX Premium
Instagram: golftango
Been a while since I've seen a Kizashi engine bay but I believe the front of the hood is sealed against the top of the bumper. The intake draws air from the space in front of the radiator through the vents around the hood latch.
golftango
You know what you may be correct. Should there be a rubber seal where the nylon fasteners are located for the shield?
Yes, there should be a rubber seal there. Suzuki calls it "front weatherstripping" with part number 7234175H00.
https://monsterfactoryparts.com/parts/2 ... eid=217481
It's not the deflector that is causing it. As Bootymac said, the intake is designed to draw air from the grill. You certainly have weather stripping missing which is likely causing the air to escape instead of being efficiently funneled into your intake.
I also have the hood deflector and it made absolutely no difference in performance before and after installation.
I should also add that the hood seals against the bumper to prevent the engine bay from pressurizing. A low pressure engine bay creates a larger pressure differential which helps increase air flow through the radiator
golftango
KuroNekko wrote:It's not the deflector that is causing it. As Bootymac said, the intake is designed to draw air from the grill. You certainly have weather stripping missing which is likely causing the air to escape instead of being efficiently funneled into your intake.
Kuro, is your weatherstripping installed with the deflector? I can't see both being installed together.
Yes, installed together. I installed it myself. Did your Kizashi not come with the weatherstripping? Did it come with the deflector?
golftango
KuroNekko wrote:Yes, installed together. I installed it myself. Did your Kizashi not come with the weatherstripping? Did it come with the deflector?
I purchased it with the deflector. Not seeing any weatherstripping. Guess I'll have to order it. Thanks!
dslatsh
Is this what it should look like?
