My Kizashi is AWD so I'll take measurements of the stock sway bar during the install. I wasn't aware that Suzuki used different bars. Has anyone else installed this on an AWD model?
Also, what stiffness are you guys running the sway bar at? I'm thinking of using the softest setting first
FYI: RRM rear sway bar on sale for $199
murcod wrote:12mm doesn't sound right, that's tiny!? Is it an AWD- read below...
Let me go back and check, It's been a while since I measured it...
It's a '12 SLS w/AWD.
Michelin Crossclimate 2
Power Stop Rotors and Pads
It's hard to tell from the picture, and I'm unable to find a higher resolution picture, but it looks like there are two positionsmurcod wrote:Is the RRM bar adjustable, I thought only the Whiteline version was?bootymac wrote: Also, what stiffness are you guys running the sway bar at? I'm thinking of using the softest setting first
But then again, the URL of the picture indicates that it's for a Honda Civic
Edit: Yeah, the picture is incorrect. It looks nothing like the Whiteline rear sway bar installed in this picture:
My (hazy) memory tells me it's only got one position? I was evaluating the two a long time back and ended up with the Whiteline - which has (actually had- the softest setting was cut off due to clearance issues!) three settings.
I run my Whiteline on the "medium" setting hole.
I received confirmation from RRM that the rear sway bar will be discontinued once it is sold out, along with other Kizashi specific parts. Very saddening to hear but it is understandable. I appreciate that they acknowledged us in the first place!
I guess it's now or never. I may buy one too. I wonder how many are in stock.bootymac wrote:I received confirmation from RRM that the rear sway bar will be discontinued once it is sold out, along with other Kizashi specific parts. Very saddening to hear but it is understandable. I appreciate that they acknowledged us in the first place!
"Low stock" is what I was told, but I don't know how many units that means. Now or never is correct though...KuroNekko wrote:I guess it's now or never. I may buy one too. I wonder how many are in stock.bootymac wrote:I received confirmation from RRM that the rear sway bar will be discontinued once it is sold out, along with other Kizashi specific parts. Very saddening to hear but it is understandable. I appreciate that they acknowledged us in the first place!
