NGK. I strongly prefer to use NGK or Denso ignition and emissions related component on Japanese cars.krell wrote:Which ignition coil brand you ordered from RockAuto?
I just think the part went bad over time. It's been nearly 80,000 miles. The NGK coil came with some info in which it discussed checking for the main reasons coils fail. It's usually because the gases get past the spark plug into the coil's boot or dirt and moisture getting into the spark plug hole from the other way. It was neither case as my failed coil boot was clean and clear of any combustion residue or dirt. The spark plug was seated nicely in pristine condition. I just think this coil went bad. The car now runs very nicely again with the new coil.SamirD wrote:Glad to hear you cured the ignition issue, although with as meticulously as you care for your car, I wonder why it failed in the first place?
I can't say capacitive touchscreens of any phone work well underwater. It's because full submersion interferes with the capacitive touch functioning between one's fingers and the screen. However, the phone has a water sensor and automatically puts the phone's camera in Underwater Mode when submerged in which the physical buttons become camera functions. This way, it can be used as an underwater camera/video.SamirD wrote: Your Kyocera seems very similar in terms of durability specs to my NEC.At the time the NEC was the only one where the touchscreen worked underwater, but looks like the Kyocera has the same capability.
Aside from not having a physical keyboard (which was one of my requirements for as much as a type on my phone), it seems like it would be the perfect upgrade for me once the NEC is no longer supported.
When out of water, the screen does work better than most others with gloves and while wet. My old iPhone5S wouldn't work too well when rain got on the screen but my DuraForce Pro works just fine.
The DuraForce Pro is marketed towards LEOs/first-responders, construction workers, and outdoorsy folks as it has features that appeal to all of those categories of people.
