I've been a bit absent from the site lately due to the busyness of life and other distractions but my Kizashi has been ever-present in my life as it continues to be my daily driver and work vehicle. In the last few months, I got around to doing a few things with the Kizashi. Maintenance-wise, I finally cleaned the throttle body, MAF sensor, and the PCV valve. I wish I did this sooner. The throttle body had black crud on the back side thus previous posts on this topic helped as a heads-up on looking for this. I'll post details on this at that thread.
While at it, I also cleaned the MAF sensor with an appropriate cleaner and also sprayed into the PCV valve with the throttle body cleaner. Prior to the cleanings, I sometimes experienced a phenomenon of the engine stalling out after starting. I'd have to start the car again and rev it to keep the engine running. Once warm, it was fine. Nonetheless, I suspected it might be related to a dirty throttle body thus cleaned it and the other parts. Now, the car starts very well each time and throttle response and acceleration has noticeably improved. I highly recommend this cleaning trio if yours is neglected. I also want to remind to disconnect the battery first. I forgot to do so and after the cleaning, the idle would "bounce" a bit before settling at normal RPM. I then disconnected the battery for a bit and it cured the matter. Things are all groovy now and have been for weeks.
Sadly, I also hurt my Kizashi recently. As I've briefly mentioned in some of my latest posts, I have another newer Suzuki: a 2015 V-Strom 650 motorcycle. Got it back in June and have been riding when time allows. As a used bike, it came with a lot of adventure touring accessories and I added a skid plate and LED headlight bulbs. Truly another one of Suzuki's many great machines with legendary reliability and durability. While not the gnarliest adventure bike, it pretty much does everything well while being a good value. Anyhow, after one ride through the local mountains, I came back and pulled up at my carport in front of the Kizashi. Cut the engine and started to get off the bike. Now 500 nearly lbs of motorcycle then started to follow me off onto the Kizashi. %#@*! I had forgotten to put down the kick stand! FML! It was a slow fall that I managed to upright but not before the clutch lever dented the hood of the Kizashi.
I plan to get paintless dent removal if it's a suitable candidate and I'll never make that mistake again. Sorry Kizashi!
- KIMG4688.JPG (214.32 KiB) Viewed 19419 times
I also took the Kizashi to Joshua Tree again when my buddy came to visit. Been there three times now in just this year but still epic each time. The park is huge so I try to visit a new place in the park each time.
The photos below are at Keys Point which is the highest point at the park accessible by paved roads. It's over 5000 feet high.
- DSC06407.jpg (388.62 KiB) Viewed 19419 times
- DSC06383.jpg (363.23 KiB) Viewed 19419 times
The photo of my Kizashi below is at Cap Rock but facing away from it.
- DSC06411.jpg (340.74 KiB) Viewed 19419 times
- DSC06414.jpg (334.66 KiB) Viewed 19419 times
Actual Cap Rock and surrounding area.
- DSC06423.jpg (332 KiB) Viewed 19419 times
- DSC06437.jpg (311.22 KiB) Viewed 19419 times
