Had the sunroof open waiting for the wife at work, and a bird pooped on the car in such as way that it splattered into the interior. Luckily, I still had the leather wipes in the car so I quickly wiped down the places where it splattered.
Caught up on the forum and started thinking about all the things I still need to finish on the car.
On Friday I was admiring the car from a distance and noticed an odd reflection in the side of the front fender arch--there's a dent there like someone hit it with a car door, but no impact. I went to check the other side and it had the opposite bend, actually being pulled out a bit.
I suspect this is damage from the chassis twisting from when I went off road in the winter entering my wife's work parking lot. Or it could have been existing damage, but I think the previous owner would have showed me as he knew every ding on the car.
I was arraigning stuff in my garage and found a air horn. Got me to thinking it would be neat putting it on the Kiz. It is a plastic aftermarket horn about six inches long with a separate small electric air pump. Where on the Kizashi is the horn and is there room nearby to put another horn? I would put a switch inside the car to switch between the OEM horn and the air horn so I can choose between a slight annoyance and someone I want to jump out of their skin.
redmed wrote:I was arraigning stuff in my garage and found a air horn. Got me to thinking it would be neat putting it on the Kiz. It is a plastic aftermarket horn about six inches long with a separate small electric air pump. Where on the Kizashi is the horn and is there room nearby to put another horn? I would put a switch inside the car to switch between the OEM horn and the air horn so I can choose between a slight annoyance and someone I want to jump out of their skin.
The Kizashi has two horns. They are directly behind the bumper next to the fog lights/air dams. If you look carefully, you will see a number of slits there. The horns are directly behind those slits on each side.
That sounds like brilliant fun. When I was young I had my windscreen jets facing outwards, and would stop at as many Zebra crossing as I could, so I could squirt the pedestrians.
I did something similar with the rear jet on my GTI to spray tailgaters
That sounds like fun also.
I had read of guys getting a Mattel Hot Wheels toy radar gun to record the speed of other cars and cause radar detectors nearby to go off, causing them to slow down. I almost got one but thought why would I want the cars around me to slow down?
redmed wrote:I had read of guys getting a Mattel Hot Wheels toy radar gun to record the speed of other cars and cause radar detectors nearby to go off, causing them to slow down. I almost got one but thought why would I want the cars around me to slow down?
I actually found one of these on sale many, many years back at a toy store for $12. I should have picked it up. I just wanted to test my radar detectors.
Sprayed down the hubs and rear sway bar links with pbblaster. I think the passenger side wheel is now wobbling a bit because the rust is no longer holding it as taught.
