Page 1 of 1
No Sound for aftermarket stereo
Posted: Fri May 15, 2020 3:34 pm
by ccwhitt
Hey, I recently bought a 10.1 Android Stereo to put in my Kizashi. I bought the wiring harness and antenna adapter and wired it up and put it in last night...everything seems to work except the sound...I have no sound whatsoever...has any had this problem?
I have a RF system in the car also, which I did get the correct S106B harness for it.
Re: No Sound for aftermarket stereo
Posted: Fri May 15, 2020 4:31 pm
by ccwhitt
Any suggestions would help.
Posted: Fri May 15, 2020 9:26 pm
by SAEED_KIZZY
it can be a problem with remote wire of amplifier check pin12 of headunit connector and and also pin5 of Amplifier connector this pins must be 12V when headunit is ON in both side.
New Bitmap Image.jpg (47.09 KiB) Viewed 3943 times
Posted: Sat May 16, 2020 1:36 am
by Drem
Mine has an option to turn the amp (high level output) on/off. I think it defaulted to off. You'll want that on for your setup.
Mine is under Options > Device > Sound > AMP ON/OFF
Look for a similar setting and verify.
