Fog/Auxilary Lights on an SE
mgp123
Hi,
New to forum. This is a silly question, but not having done it thought I would ask.
Can I easily add auxiliary lights to my 2012 SE? My concern is mounting them and then my plastic parts in the bumper melting.
Thanks
Wonson92
How/where are you planning on mounting them? Aftermarket kit im assuming?
2011 Premium Silver XL
The best (easiest) option would be to look on Ebay for the factory fog light kit. It will include everything you need.
If you want driving lights (for long distance vision at night) then you'll have to DIY.
Suzuki offers OEM fog lights as an accessory and you can install them on your SE, I believe. Call to make sure it's compatible with your car, although I believe it is.
Here's some info:
http://www.oemsuzukiparts.com/partlocat ... logid=5512
If you want driving lights, then as Murcod said, you will have to get aftermarket products. Someone on this forum recently added a LED driving light (not a DRL) with very impressive results. However, driving lights are really only intended for offroad/rural roads with no street lighting. They are not for use in city/suburban areas.
