What tires are best?
I’m sorry my right up here is hard to understand. I’m mechanic not a writer. I think if you take this to your local mechanic he could understand it and help you out. The toe has to be measured and know where you wanting to go before loosening and attempting adjustment. The aluminum arm is for the camber. You do not have to adjust this I would leave it alone unless if it was drastically out. Camber is not really a wearing angle like toe. If you can get the nut loose easy, I think you should be able to force turn the adjustment with a long breaker bar and maybe even a pipe added to it. I’ve only used the turnbuckle repair twice now. The turnbuckle was harvested off of a wore out Toyota Camry rear control arm anywhere between 1992 and 2001.
