Stereo Installation
Runner
I purchased my Kizashi without any audio system. I want to install my own system. I have removed the AC control panel, but am having trouble removing the upper panel, where the audio unit will go. Also, I don't see the wiring harness that should provide me access to power, ground, and the speaker wiring. Anyone have any information regarding this?
Search, there are several threads on this with the part numbers for the scoche harness and everything
Runner
Yeah, I have the Scosche harness. It gets wired to my stereo unit and has a male plug that mates with the female receptacle in the car. It was the female receptacle that I couldn't locate. In the space where a double din stereo unit can go, I had a plastic pocket and a blank panel. It turned out that the car's receptacle was connected to the back of the pocket. I have since installed my stereo unit, and it is working great.
BxKizashiS
The upper panel is held by 2 screws on each corner. Wish I could take a pic but u can't miss it. Use a flashlight. U might need a extended Phillips screwdriver. Then once those 2 screws are out you pop it out like u did the AC panel
2012 Suzuki Kizashi S AWD
Facebook.com/jpreludesi
IG: N2OKizashi
