Install Auto-off - Auto-Dim Headlight Kit
picabotwo
I have a 2012 Kizashi SE and I wanted to install an Auto-off/Auto-Dim headlight kit. Does anyone have a service guide or wiring guide for the headlights?
This is the kit:
Universal Auto On/Off Headlights Sensor w/ Switch
http://www.modifystreet.com/Universal-A ... witch.html
Thanks!
Josh
Dthrill_08
I wish someone would help. This is a great idea for us SE drivers lol. I don't mind turning it on manually but if my 01 Lincoln LS had it why can't this Zashi.
Dthrill_08 wrote:I wish someone would help. This is a great idea for us SE drivers lol. I don't mind turning it on manually but if my 01 Lincoln LS had it why can't this Zashi.
It was offered only in the SLS.
I bet there is a way to wire the sls kit into a lower trim Kizashi, but it may not be worth the cost/effort.
Sometimes it's easy to switch/add stuff as all the wiring is all there. I think the Kizashi has this in a lot of places. I put in some infinitely variable wipers in my Accord by swapping the stalk and a control module. Lots you can do with factory swaps.
redmed
SamirD wrote:I bet there is a way to wire the sls kit into a lower trim Kizashi, but it may not be worth the cost/effort.
I would like to add auto/lights & cruise control to my Kizashi S. My base Corolla has auto/lights and have forgotten to turn off the lights on the Kiz a quite a few times and had the annoying ding-ding reminder. I had studied the wiring diagram hoping that I could add a module or switch to activate the cruise control. After checking I could not get enough information to do it. :?
17 Sienna
There's a lot of sensors needed for both auto lights and cruise control which are probably missing. :( Probably won't be easy. :(
