The problem I'm running into is when I test fit the head unit to the stock suzuki double din piece, the radio face is approximately 1mm too wide to fit, but also 2 or 3mm too short to fill the hole heightwise. There's no separate trim piece that come with the radio. Can anyone give me insight? Was the radio supposed to come with a trim plate or have you members that used the stock plate had to cut the sides to get the headunit to fit?
I was hopeful this would be a zero headaches install but I should've known better, not sure it's ever gone that way.
