Suzuki Cross Compatibility
rannel.bradley
I searched for but didn’t see any threads about Suzuki or other make cross compatibly.
I know many auto makers use a lot of the same parts across their models, even spanning different manufacturers. Is there a list of parts somewhere?
If not I’d like to start one. Do you guys know of any parts that are the same?
KansasKid
I'm not sure what the part numbers are, but the Kizashi uses a Jatco CVT that's probably shared by some Nissan vehicles.
It was determined that the Kizashi uses the same fog light as a Toyota Yaris of the same model year. If you have fog lights and ever damage them, search for and buy a new one for a Toyota Yaris and you'll pay less than a used one from a junked Kizashi.
andrés.ignacio
KuroNekko wrote:It was determined that the Kizashi uses the same fog light as a Toyota Yaris of the same model year. If you have fog lights and ever damage them, search for and buy a new one for a Toyota Yaris and you'll pay less than a used one from a junked Kizashi.
Indeed, the OEM fog light comes from VALEO, part number: 88970
You can find a lot of models that actually uses this fog lights
Using this list below you can search for the cheap aftermarket option for your Kizashi.
LEXUS GS350 2013-2015
LEXUS GS450H BASE 2013-2015
LEXUS HS250H PREMIUM 2010-2012
LEXUS HS250H ULTRA PREMIUM 2010-2011
LEXUS HS250H 2010-2011
LEXUS IS F 2008-2012
LEXUS LX570 2008-2013
LEXUS RX350 2008-2013
LEXUS RX450H BASE 2.4L GAS 2AZFE DESIGN 2010-2015
TOYOTA CAMRY BASE VIN L 1.8L 2ZRFE DESIGN 2011
TOYOTA CAMRY CE 2.4L GAS 2AZFE DESIGN 2009
TOYOTA CAMRY HYBRID 2.4L ELECTRIC/GAS 2AZFXE DESIGN 2007-2008
TOYOTA CAMRY HYBRID 2.4L ELECTRIC/GAS 2AZFXE DESIGN SOLD IN UNITED STATES 2007-2011
TOYOTA CAMRY LE 2.4L GAS 2AZFE DESIGN 2010-2011
TOYOTA CAMRY LE 2.5L GAS 2ARFE DESIGN SOLD IN UNITED STATES 2007-2009
TOYOTA CAMRY LE 3.5L GAS 2GRFE DESIGN SOLD IN UNITED STATES 2007-2011
TOYOTA CAMRY LE 3.5L GAS 2GRFE DESIGN 2010-2011
TOYOTA CAMRY SE 2.4L GAS 2AZFE DESIGN 2007-2009
TOYOTA CAMRY SE 2.5L GAS 2ARFE DESIGN SOLD IN UNITED STATES 2010-2011
TOYOTA CAMRY SE 3.5L GAS 2GRFE DESIGN 2011
TOYOTA CAMRY SE 3.5L GAS 2GRFE DESIGN SOLD IN UNITED STATES 2007-2011
TOYOTA CAMRY XLE 2.4L GAS 2AZFE DESIGN 2007-2009
TOYOTA CAMRY XLE 2.5L GAS 2ARFE DESIGN SOLD IN UNITED STATES 2010-2011
TOYOTA CAMRY XLE 3.5L GAS 2GRFE DESIGN SOLD IN UNITED STATES 2007-2011
TOYOTA CAMRY XLE 3.5L GAS 2GRFE DESIGN 2010-2011
TOYOTA COROLLA BASE VIN U 1.8L 2ZRFE DESIGN 2009-2010
TOYOTA COROLLA BASE 2.7L GAS 1ARFE DESIGN 2011
TOYOTA COROLLA CE VIN L 1.8L 2ZRFE DESIGN 2009
TOYOTA COROLLA CE VIN U 1.8L 2ZRFE DESIGN 2009-2010
TOYOTA COROLLA LE VIN L 1.8L 2ZRFE DESIGN 2009
TOYOTA COROLLA LE VIN U 1.8L 2ZRFE DESIGN 2009-2010
TOYOTA COROLLA S VIN L 1.8L 2ZRFE DESIGN 2009
TOYOTA COROLLA S VIN U 1.8L 2ZRFE DESIGN 2009-2010
TOYOTA COROLLA XLE VIN L 1.8L 2ZRFE DESIGN 2009
TOYOTA COROLLA XLE VIN U 1.8L 2ZRFE DESIGN 2009-2010
TOYOTA COROLLA XRS 2.4L 2AZFE DESIGN 2009
TOYOTA COROLLA BASE 2009-2010
TOYOTA COROLLA CE 2011
TOYOTA COROLLA LE 2011
TOYOTA COROLLA S 2012-2013
TOYOTA COROLLA 2011
TOYOTA HIGHLANDER BASE 3.5L GAS 2GRFE DESIGN 2008-2010
TOYOTA HIGHLANDER HYBRID 3.3L ELECTRIC/GAS 3MZFE DESIGN 2008-2010
TOYOTA HIGHLANDER HYBRID 3.5L ELECTRIC/GAS 2GRFXE DESIGN 2011
TOYOTA HIGHLANDER HYBRID LIMITED 3.3L ELECTRIC/GAS 3MZFE DESIGN 2009-2011
TOYOTA HIGHLANDER HYBRID LIMITED 3.5L ELECTRIC/GAS 2GRFXE DESIGN 2008-2011
TOYOTA HIGHLANDER LIMITED 3.5L GAS 2GRFE DESIGN 2011
TOYOTA HIGHLANDER SPORT 3.5L GAS 2GRFE DESIGN 2008-2011
TOYOTA HIGHLANDER 2012
TOYOTA HIGHLANDER 2008-2010
TOYOTA PRIUS BASE 2.4L 2AZFE DESIGN 2010-2012
TOYOTA RAV4 BASE 2.5L 2ARFE DESIGN SOLD IN UNITED STATES 2006-2008
TOYOTA RAV4 BASE 3.5L 2GRFE DESIGN SOLD IN UNITED STATES 2006-2011
TOYOTA RAV4 BASE 3.5L 2GRFE DESIGN 2009, 2011
TOYOTA RAV4 LIMITED 2.4L 2AZFE DESIGN 2006-2008
TOYOTA RAV4 LIMITED 2.5L 2ARFE DESIGN SOLD IN UNITED STATES 2009, 2011
TOYOTA RAV4 LIMITED 3.5L 2GRFE DESIGN 2009
TOYOTA RAV4 SPORT 2.4L 2AZFE DESIGN 2006-2008
TOYOTA RAV4 SPORT 2.5L 2ARFE DESIGN SOLD IN UNITED STATES 2009, 2011-2012
TOYOTA RAV4 SPORT 3.5L 2GRFE DESIGN 2006-2011
TOYOTA RAV4 BASE 2012
TOYOTA RAV4 2006-2011
TOYOTA YARIS CE 2007-2009
TOYOTA YARIS LE 2007-2008
TOYOTA YARIS RS 2010-2014
TOYOTA YARIS S 2007-2008
TOYOTA YARIS 2007-2008
TOYOTA YARIS 2007-2009
andrés.ignacio
OEM Akebono front brake pads cod: ACT1338 for the kizashi also fits perfect in a Nissan Maxima, Rogue, Juke Nismo RS...
May be another brand or model too.
The Akebono ASP1338 is the High Performance option.
rannel.bradley
KansasKid wrote:I'm not sure what the part numbers are, but the Kizashi uses a Jatco CVT that's probably shared by some Nissan vehicles.
Would it bolt right up to same engine? Plug and play?
Probably not as it may have a different housing to mate to the Suzuki engine. Also, the programming of the CVT would likely be different from the other vehicles that used the same CVT as they were Nissan and Mitsubishi CUVs.
KansasKid
KuroNekko wrote:Probably not as it may have a different housing to mate to the Suzuki engine. Also, the programming of the CVT would likely be different from the other vehicles that used the same CVT as they were Nissan and Mitsubishi CUVs.
That's a good point. I didn't even think about the ECU programming for the CVT.
