Hub center bore size??
What is the hub center bore size for the 2012 Kizashi Sport? I found different answers so if you have the real size, please let me know. Thank you in advance.
http://www.kizashiclub.com/forum/viewto ... &hilit=hub I haven't verified it, but that was what I found when researching.
I contacted Suzuki Canada and they said 60 mm. If you want to buy wheels for you Kizzy, make sure the hub center bore is 60mm or more.
I'd say 60.1mm is the correct measurement - unless they specified 60.0mm? (Usually with centre bore measurements it's specified to a fraction of a millimetre, the wheel is supposed to be a tight fit on the hub.)
