Was gonna get a RPM PULLEY then i stumble on this little article in the Kia forum .. what you folks think should i go ahead with the RPM Pulley ?
http://www.forteforums.com/forums/perfo ... amper.html
The Danger of Power Pulleys &
Understanding the Harmonic Damper
BY STEVE DINAN OF DINAN BMW
I have been threatening for a long time to write a series of technical articles to educate consumers and to dispel misconceptions that exist about automotive after-market technology. Motivated by problems with customer's cars resulting from the installation of power pulleys, I wish to explain the potential dangers of these products and address the damage they cause to engines.
The theory behind the power pulley is that a reduction in the speed of the accessory drive will minimize the parasitic losses that rob power from the engine. Parasitic power losses are a result of the energy that the engine uses to turn accessory components such as the alternator and water pump, instead of producing power for acceleration. In an attempt to minimize this energy loss, many companies claim to produce additional power by removing the harmonic damper and replacing it with a lightweight assembly. While a small power gain can be realized, there are a significant number of potential problems associated with this modification, some that are small and one which is particularly large and damaging!
The popular method for making power pulleys on E36 engines is by removing the harmonic damper and replacing it with a lightweight alloy assembly. This is a very dangerous product because this damper is essential to the longevity of an engine. The substitution of this part often results in severe engine damage.
It is also important to understand that while the engine in a BMW is designed by a team of qualified engineers, these power pulleys are created and installed by people who do not understand some very important principles of physics. I would first like to give a brief explanation of these principles which are critical to the proper operation of an engine.
1) Elastic Deformation
Though it is common belief that large steel parts such as crankshafts are rigid and inflexible, this is not true. When a force acts on a crank it bends, flexes and twists just as a rubber band would. While this movement is often very small, it can have a significant impact on how an engine functions.
2) Natural Frequency
All objects have a natural frequency that they resonate (vibrate) at when struck with a hammer. An everyday example of this is a tuning fork. The sound that a particular fork makes is directly related to the frequency that it is vibrating at. This is its "natural frequency," that is dictated by the size, shape and material of the instrument. Just like a tuning fork, a crankshaft has a natural frequency that it vibrates at when struck. An important aspect of this principle is that when an object is exposed to a heavily amplified order of its own natural frequency, it will begin to resonate with increasing vigor until it vibrates itself to pieces (fatigue failure).
3) Fatigue Failure
Fatigue failure is when a material, metal in this case, breaks from repeated twisting or bending. A paper clip makes a great example. Take a paper clip and flex it back and forth 90° or so. After about 10 oscillations the paper clip will break of fatigue failure.
The explanation of the destructive nature of power pulleys begins with the two basic balance and vibration modes in an internal combustion engine. It is of great importance that these modes are understood as being separate and distinct.
1) The vibration of the engine and its rigid components caused by the imbalance of the rotating and reciprocating parts. This is why we have counterweights on the crankshaft to offset the mass of the piston and rod as well as the reason for balancing the components in the engine.
2) The vibration of the engine components due to their individual elastic deformations. These deformations are a result of the periodic combustion impulses that create torsional forces on the crankshaft and camshaft. These torques excite the shafts into sequential orders of vibration, and lateral oscillation. Engine vibration of this sort is counteracted by the harmonic damper and is the primary subject of this paper.
Torsional Vibration (Natural Frequency)
Every time a cylinder fires, the force twists the crankshaft. When the cylinder stops firing the force ceases to act and the crankshaft starts to return to the untwisted position. However, the crankshaft will overshoot and begin to twist in the opposite direction, and then back again. Though this back-and-forth twisting motion decays over a number of repetitions due to internal friction, the frequency of vibration remains unique to the particular crankshaft.
This motion is complicated in the case of a crankshaft because the amplitude of the vibration varies along the shaft. The crankshaft will experience torsional vibrations of the greatest amplitude at the point furthest from the flywheel or load.
Harmonic (sine wave) Torque Curves
Each time a cylinder fires, force is translated through the piston and the connecting rod to the crankshaft pin. This force is then applied tangentially to, and causes the rotation of the crankshaft.
The sequence of forces that the crankshaft is subjected to is commonly organized into variable tangential torque curves that in turn can be resolved into either a constant mean torque curve or an infinite number of sine wave torque curves. These curves, known as harmonics, follow orders that depend on the number of complete vibrations (cylinder pulses) per revolution. Accordingly, the tangential crankshaft torque is comprised of many harmonics of varying amplitudes and frequencies. This is where the name "harmonic damper" originates.
Critical RPM's
When the crankshaft is revolving at an RPM such that the torque frequency, or one of the harmonic sine wave frequencies coincides with the natural frequency of the shaft, resonance occurs. Thus, the crankshaft RPM at which this resonance occurs is known a critical speed. A modern automobile engine will commonly pass through multiple critical speeds over the range of its possible RPM's. These speeds are categorized into either major or minor critical RPM's.
Major and Minor Critical RPM’s
Major and minor critical RPM's are different due to the fact that some harmonics assist one another in producing large vibrations, whereas other harmonics cancel each other out. Hence, the important critical RPM’s have harmonics that build on one another to amplify the torsional motion of the crankshaft. These critical RPM’s are know as the "major criticals". Conversely, the "minor criticals" exist at RPM's that tend to cancel and damp the oscillations of the crankshaft.
If the RPM remains at or near one of the major criticals for any length of time, fatigue failure of the crankshaft is probable. Major critical RPM’s are dangerous, and either must be avoided or properly damped. Additionally, smaller but still serious problems can result from an undamped crankshaft. The oscillation of the crankshaft at a major critical speed will commonly sheer the front crank pulley and the flywheel from the crankshaft. I have witnessed front pulley hub keys being sheered, flywheels coming loose, and clutch covers coming apart. These failures have often required crankshaft and/or gearbox replacement.
Harmonic Dampers
Crankshaft failure can be prevented by mounting some form of vibration damper at the front end of the crankshaft that is capable of absorbing and dissipating the majority of the vibratory energy. Once absorbed by the damper the energy is released in the form of heat, making adequate cooling a necessity. This heat dissipation was visibly essential in Tom Milner's PTG racing M3 which channeled air from the brake ducts to the harmonic damper, in order to keep the damper at optimal operating temperatures. While there are various types of torsional vibration dampers, BMW engines are primarily designed with "tuned rubber" dampers.
It is also important to note that while the large springs of a dual mass flywheel absorb some of the torsional impulses conveyed to the crankshaft, they are not harmonic dampers, and are only responsible for a small reduction in vibration.
In addition to the crankshaft issue, other problems can result from slowing down the accessories below their designed speeds, particularly at idle. Slowing the alternator down can result in reduced charging of the battery, dimming of the lights, and computer malfunctions. Slowing of the water pump and fan can result in warm running, while slowing of the power steering can cause stiff steering at idle and groaning noises. It is possible to implement design corrections and avoid these scenarios, but this would require additional components and/or software.
Our motto at Dinan is "Performance without sacrifice" We feel our customers expect ultra high performance along with the legendary comfort and reliability of a standard BMW.
While it is common that a Dinan BMW is the fastest BMW you can buy, performance is not our only goal. Dinan isn't just trying to make the fastest car. Instead a host of considerations go into the development of our products. Dinan puts much more effort into these other areas than does our competition.
These considerations are Performance, Reliability (Warranty), Driveability, Emissions, Value, Fit and Finish. We feel that the power pulley is a bad way to get extra power from and engine and the potential for serious engine damage is too great.
This is a simplified explanation meant to be comprehensible by those who are not automotive engineers. In trying to simplify an extremely complex topic some precision was sacrificed although we believe this explanation to be as accurate as possible. We encourage our customers to educate themselves and understand the automotive after-market because we believe that our products are the best researched, engineered, and fabricated products available.
For those interested in a more in depth and technical explanation of this topic, the reference book is Advanced Engine Technology, written by Heinz Heisler MSc,BSc,FIMI,MIRTE,MCIT. Heinz Heisler is the Head of Transportation Studies at The College of North West London. His book is distributed in this country by the SAE (Society of Automotive Engineers).
I haven't read all the article, but yes the pulley (also known as a harmonic balancer) is there to counteract destructive vibrations within the engine. So, don't change it!
I read an article a while back about the development of the modern combustion engine and how a company was having problems with the engines self destructing. Basically, one particular engine lasted and lasted- they discovered the front pulley hadn't been tightened and was moving/ vibrating. From that they developed the "harmonic balancer".
yep...had a SB 283 in an Impala back in my teenage days that had all of a sudden developed a wicked vibration in the motor for. Tried everything to get rid of the vibe, the usual stuff...plugs, wires, cap rotor, points). After talking to an 'old-timer' about it, and he asked me if I'd pulled the balancer off and had a look at it. Uhhh no, why the hell would I do that I asked? He told me to pull it and my question would be asnwered. Big chunk of dry rotted rubber was missing, problem solved.
sold)
The article makes a lot of sense given the purpose of the harmonic balancer. In addition, the article was written by Steve Dinan who is a renown tuner of BMWs.
Personally, I have never been a big fan of modifications, especially to engine components. Though they may give you greater performance, it is almost always at the cost of engine reliability, durability, and therefore longevity. I am the kind of car owner who pays in cash and keeps my car for a long time so I want my car to run well for as long as possible. Things like lightweight pulleys simply do not outweigh the negatives and risks they bring.
Also, the turbo mod for the Kizashi is enticing, but like most aftermarket turbo cars, the turbo will probably shorten engine life by half, if not a fourth. Despite an aftermarket manufacturer's testing claims, they are simply bolting on a turbo and intercooler to an engine that was NOT DESIGNED with a turbo in mind. The turbo would bring additional stresses that the rest of the engine components may not be able to contain well. If I was to get a turbo, I would also look into upgrading my oil pump, fuel pump, water pump, cams, valves, injectors, clutch, etc. to ensure the overall reliability and durability of the engine in the long run. Just because the Kizashi's excellent chassis handles the added power well, it doesn't mean the engine and the transmission will. I see the engine and its components as kind of like an ecosystem and drastically changing one part of it may be detrimental to the other parts that were not designed for the change.
If you want performance mods, the best parts typically are an intake and exhaust. These mods will give you more power (although not that much) and will make your car sound more aggressive. Unlike engine parts like the pulley, these parts are designed by the OEM foremost for their silencing qualities. It's sound suppression, not engine durability, that is the focus for these parts. Yes, the intake air must be filtered well, but the airbox design is actually restrictive to keep noise levels low. Therefore, if you want more sound and power, then a more free-flowing set up is good.
I personally had a short-ram intake in my old Impreza. It helped the car rev faster to get to the powerband quicker. On the other hand, it required maintenance as it was a K&N-type filter and I seriously doubt these oiled filters actually filter particles better than a OEM drop in filter. It's airflow that they do better, not filtration. Therefore, I felt that I was sacrificing filtration quality for the sake of a bit of performance.
I am leaving my Kizashi stock for now. Definitely until the basic warranty is up. Probably continue to leave it stock after that.
If I had such a power lust, I would just get a more powerful car. If I wanted a turbo so bad, I would just get a Subaru WRX; a car that was DESIGNED for a turbo.
Personally, I think components like exhausts, intakes, chipsets, etc. are overrated and components that ACTUALLY make a big difference are overlooked. The best example? Tires. Tires are the only thing that keep your car on the surface it travels. While people obsess about power, they sometimes forget about the means to which it connects to the pavement. Researching and purchasing the perfect tires for your driving style, terrain, and weather conditions would probably result in a more rewarding driving experience than some lightweight pulley that could damage your engine in the long run.
Lastly, and most importantly, the driver. Mod your car all you want, but in the hands of a poor driver, it will not be all that better. The driver himself is one that also (if not the most) can improve. Practicing and driving on more challenging roads or even enrolling in a driving school (no, not driver's ed, but a professional racing type of class) would increase the skill of the driver. It's amazing what talented drivers can do in any car whether an exotic or an economy car.
This is true. A lot of people focus mainly on small insignificant modifications to gain 5-10hp (for a lot of money). A better approach is tyres and weight reduction. Good quality very light weight wheels can do way more good than small engine/exhaust mods. If you replace stock wheels that weigh approximately 20kg with some light weights of 10kg, that equates to 40kg lighter vehicle (that's almost 1 passenger), not to mention better handling due to less unsprung weight.KuroNekko wrote: Personally, I think components like exhausts, intakes, chipsets, etc. are overrated and components that ACTUALLY make a big difference are overlooked. The best example? Tires. Tires are the only thing that keep your car on the surface it travels. While people obsess about power, they sometimes forget about the means to which it connects to the pavement. Researching and purchasing the perfect tires for your driving style, terrain, and weather conditions would probably result in a more rewarding driving experience than some lightweight pulley that could damage your engine in the long run.
As soon as I get some spare cash, I'm getting Enkei light weights
BMW E46 330i SMG
Suzuki Kizashi 6MT
Suzuki Kizashi 6MT
