What makes an(y) aftermarket rear sway bar "better" than the bar found on my stock 2011 S AWD?
Will it enhance handling? How?
Will it cause any issues with handling?
Will it cause any issues at all?
Is it "worthwhile"?
I am seriously interested.......
serious query (non-argumentative):
How much do you know about what a sway bar does?
Usually, aftermarket models are stiffer with stiffer bushings. This will help to minimize body roll, but also decrease the "independent" action of the suspension, potentially decreasing the ride quality in some situations.
So 'the' aftermarket bar is of larger diameter (or stiffer steel)?
Its bushings are firmer?
And I can tell after installation by the reduction in front tire feathering due to the car's flatter cornering stance?
And 'the' aftermarket bar is therefore worthwhile?
I have a rear swaybar on mine. i got it for free from an Australian company here and it has 3 adjustable settings.
The car is much flatter through corners, less bodyroll and less oversteer as well so overall im very happy
I didn't install it myself, the company that supplied it did. They were looking for a kizashi to test fit a swaybar for like 2 months and couldnt find one until someone told me about them.
So i got it for free, installed and everything and they asked me is it ok to install some more suspension related upgrades in the future for the kizashi and i said hell yes.
I was watching the guy install and it looked pretty easy, just a few bolts here and there but he had it up on a hoist too which made it easy.
The RRM rear swaybar is 19mm thick i think the one i got was 18mm, stock is 15mm i think.
