After a dip and red paint
Irmolax
I've only had the pleasure to own the Kizashi for two weeks now but I've givin' her a lot of my time. Lemme know what ya'll think with the plastidip job and some red calipers.
Looking sharp, but I'm curious as to how long Plastidip lasts on wheels. With the higher temperatures, brake dust, and other factors, I figure the paint will wear off or chip faster than other components. Even the continual touch of a hand will wear off Plastidip. I've seen an entire car Plastidipped but the driver's side door handle was worn through and you could easily see the original color.
Irmolax
KuroNekko wrote:Looking sharp, but I'm curious as to how long Plastidip lasts on wheels. With the higher temperatures, brake dust, and other factors, I figure the paint will wear off or chip faster than other components. Even the continual touch of a hand will wear off Plastidip. I've seen an entire car Plastidipped but the driver's side door handle was worn through and you could easily see the original color.
Well unfortunately I'm not an expert on plastidipping, but cake it up. Lite first spray then work it up from that. I threw on 5 coats then followed up with 4 coats of glossifyier. I'm hoping it'll keep itself together. But I figure washing them with slowly remove the dip and hitting curbs will eat it up.
the calipers have high temp caliper paint.
It looks good!
Irmolax
What do yall think about paint half of the headlights from the 3 clear line up to give a meaner look?
BLyons
I assume you mean something similar to this. Personally, I've never been a fan of eyelids on cars, but maybe if it was body colored it would look halfway decent.
Black 2011 Sport SLS AWD
Irmolax
I agree with you. But I was trying to decrease the size of the headlamp to give it a sportier look. I used plastidip but would recommend using vinyl. Over the course of 3 washes, the plastidip accumulated water marks. So I removed the plastidip. But if anyone was looking to do this and needed a visual. Here ya go
Motasem
Here's mine.
