FYI: OEM oil filter dissected
I took a hacksaw to the OEM filter on my Kizashi (PN 16510-61A31, made in Japan) and wanted to share my findings. This filter was installed by the dealer and has ~6,500 km (or ~4,000 miles) with 5w30 synthetic oil.
Here is everything laid out:
The filter case measures 72mm in diameter (base) and 85mm in height.
The filter end caps are made of a thin, pourous fiber material. The filter media was securely glued onto the end caps.
Here are the measurements of the filter media:
  • Pleat depth: 1.5cm (0.59")
    Media height: 6.5cm (2.56")
    Media length: 152.4cm (60")
    Media area: 990.6cm^2 (1536 sq-in, 10.7 sq-ft)
Metal center tube:
The bypass valve uses a coil spring design that is still functional. The anti-drainback valve is made of silicon and is very pliable. The exterior o-ring is made of nitrile.
Hope this was informative!
Those end caps don't appear to be paper. Looks more like filter media of some sort to me. Cut open a cheapo Fram and you will see paper ends (that collapse).
Excellent info and photos. Thanks.
It goes to dispel the myth that many have thinking the OEM filter is the best one. It's simply not always the case. It's best for your warranty, but not necessarily for your engine. However, it does look like a decent filter but nothing to bother going out of my way for.
I did some more dissecting and took a closer look at the filter media and the end caps. The end caps appear to be a pourous fiber material (not paper). The filter media was securely glued onto the end caps.
I also took some more photos. I'll update the first post with the new information.
Cool pics...thanks for taking the time to dissect it further. I would agree it's not the best and wouldn't go out of my way to get them, but for the warranty and its low cost (for me, cheaper than a NAPA gold which is my go to filter), they're good enough for me.
This is an autopsy. :lol:
Interesting fact:
There are real life "automotive autopsies" in the field of law. In criminal law, it's for cases involving vehicular manslaughter in which the prosecution wants to prove that there wasn't any mechanical failure with the car that caused the accident and that it was 100% the fault of the driver.
I've seen a few of these reports and they are interesting for car enthusiasts.
honsonwong
Great info, thanks for sharing.
Thanks for the messy dissecting work!
It's interesting to see the filter getting condemned purely on appearance. Without testing the filter's efficiency (and ability to supply the correct oil pressure and flow) - how can it be said it's not a good filter?
On the Suzuki XL-7 there is a known issue with timing chain rattle. Oddly enough, many people have found the OEM filter is best for reducing the timing chain rattle at start up. I've tried many reputable after market brands and had some horrible results with chain rattle for extended periods.
Aftermarket filters are often a case of "if it screws on, it fits". Whereas, I've found Suzuki spec different model oil filters for different engines- even though those engines could physically use the same filter. You're guaranteed the oil pressure, flow and filtering are correct spec when using the OEM filter.
It's something to think about.
Yep, that's mainly why I use them. I don't know what the engineers were thinking when they decided on the filter they did for the car's engine. So for warranty reasons, and peace of mind, I simply stock up on the OE ones when I'm at the ex-dealer twice a year between the 2 zuks for inspections.
It would be interesting to see the differences between the Made in China Suzuki Filter and this Made in Japan Suzuki filter.
murcod wrote:Thanks for the messy dissecting work!
No one is really condemning the OEM filter but to assume that just because it's the OEM filter, it would be the best filter you can get is a fallacy.
Keep in mind that OEMs have to manufacture at a certain price point. They can't make their filters cost too much which then affects the quality of the materials and construction.
While I agree that there are many benefits to OEM filters that outweigh the costs, some folks like me would have to be greatly inconvenienced to get my hands on them. On the contrary, I could get something like a Mobil 1 oil filter at my local auto parts store which is most likely a superior filter (it costs more too).
Lastly, consider the fact that Suzuki is not designing nor manufacturing the filter. No car manufacturer does. They simply have parts/filter manufacturers supply the filters that they label as OEM. There are many "aftermarket" filters that are identical to OEM filters because that filter maker is the one that manufactured the OEM filter in the first place.
