Coolant for the Kizashi
documental wrote: Wed Jun 30, 2021 2:51 pm My coolant reservoir cap got lost and as a result my coolant level is basically zero (oops). I'm amazed the car has been driving OK like this for a while, though I've noticed my AC doesn't work properly at speed, which probably relates to the engine overheating.
First I needed a cap, which proved impossible online, but I found a pill-bottle cap that fits perfectly. Hope it won't melt!
Now I need to top up the fluid. The level is so low, I honestly can't tell the colour, but it looks blue.
Looking at using this option to top it up, which Crappy Tire (here in Canadia) claims will work with the car. It's cheap, but do you think it will be good enough?
OEM 50/50 Premixed Anti-Freeze/Coolant, Honda/Acura/Subaru, 3.78-L
https://www.canadiantire.ca/en/pdp/oem- ... 93080.html
I also might need two bottles to fill it. Not sure of the volume of the reservoir.
Yes, any blue coolant will work as it's a formula designed for most modern Japanese makes. Suzuki is one of them. A 50/50 premix will be good for about 99% of drivers.
Keep in mind the reservoir is technically an overflow container. The cooling system will overflow and draw from that reservoir as needed. The actual coolant that matters is largely contained in the radiator so make sure that is topped off (when the engine is cooled down).
I wouldn't worry too much about that reservoir cap. It's not pressurized so a pill bottle cap should be fine as a replacement.
it's been around a year since I changed my coolant from Blue into Toyota SSLC (the red one). I decided to remove the thermostat to check for any corrosion. and here is a result
inside of water pump
no corrosion :D since I removed the thermostat I decided to change to the new one :
so I guess changing blue coolant to red done no harm to the engine.
KlutzNinja
Caps for both the radiator and water/coolant reservoirs are available online. KuroNekko found one on MonsterParts a while back for real cheap, but the link doesn’t work anymore. So here’s the link to MegaZip, which is a pretty good site for Kizashi parts.
https://www.megazip.net/zapchasti-dlya- ... 00-9849626
RS350
Were you able to find the replacement cap for the coolant reservoir? I lost mine and am looking for a new one.
NickL
I am about to change the Coolant for my Kizashi in upcoming weeks but it is a bit hard to find the original suzuki Long Life Coolant. I found the 5L Package on one website but if I am right, I need. 7 liters to fill in so one 5L kanister won't be enough and 2 would be too much. And there is no 1 or 2L bottles for sale...
Is it mandatory to use only original Suzuki Coolant? Can I substitute it with.something else equally good?
I like the Toyota red stuff. I would think it would be very easy to find .
NickL
Thanks.
Is the Engine Block in Kizashi made from Aluminum? Is there anything else to pay attention when choosing the right Coolant for Kizashi?
NickL wrote: Mon Oct 24, 2022 9:15 am Thanks.
Yes, aluminum block. I actually called Suzuki corporate in the US about the matter of the proper engine coolant. I was told that we can use any Super Long-Life Blue coolant because they are basically all the same. Many Asian cars ranging from Nissan to Hyundai apparently use it. I then picked up a few jugs of Pentosin 50/50 premix Super Blue coolant and changed my coolant a while back.
NickL
I finally changed the Coolant in my Kizashi few weeks ago. Even though the previous Coolant in the system wasn't dirty at all, it had some pink color and it was obvious that previous owner allready changed it, but when I had no idea. I went to Suzuki Dealer which is only 2 miles away from me and asked them about the blue Super Long life Coolant for Suzuki. They sold it to me but they had only 5 liters package and Suzuki needs according to the service Manual arround 6,5 liters in the system. So I ended up buying two packages and now I have 3,5 liters left but what the heck. I am glad that now the appropriate Coolant is inside. I also changed the rear brake pads and brake oil, put the winter Tyres on. And me and my faitfull Kizzy keep rooling further. :)
