Automatic headlamp levelling not working
Bytez
Hello everyone,
I have the following problem: The automatic headlamp leveling does not work with both headlamps on my 2010 Kizashi. I can't imagine that it's the motors as the problem exists on both sides.
- Has anyone ever had this problem?
- Does anyone know where the fuse for this is located?
- Does anyone know how it is wired in case it is a cable break?
Thanks in advance
Greetings from Germany
Andreas
You'll have to check the owner's manual or the service manual for the fuse. Does anything else not function properly? How about the headlight washers?
Unfortunately, North American owners will not have first-hand experience on this matter because none of the Kizashis sold here had factory HID low beams with auto-leveling and headlight washers.
Bytez
Unfortunately, the fuse for this function is not in the manual. Otherwise, everything works normally. I think I have found one of the sensors (see pictures in the links). It is on the right side of the front suspension.
https://ibb.co/vBhVNqs
https://ibb.co/b3LgfFP
The "Back" fuse on JB No.2 below the steering wheel is the fuse for the automatic headlight level module, but it is not a problem if it is blown; a bunch of other modules will stop working, too.
do you see the indicator for Automatic leveling light on the Instrument Cluster?
