No problem. I should have included it a long time ago. In fact, I should have made this thread a sticky here a long time ago.bootymac wrote:Thanks! That should make life easier for future users.
Better late than never.
The inner diameter was made smaller according to the TSB.bootymac wrote:I've also just realized that the TSB only applies within the warranty period. Seeing how little I drive my Kizashi, my warranty will likely expire by the time my shocks actually fail. I figure I should do something sooner rather than getting potentially screwed in the future.
I went through the TSB and the process is pretty straightforward if you have the tools and experience.
As for the bump stops, it appears that the revisions simply have channels cut across the top and down the side; the inner area look the same. Makes sense seeing how the idea is to allow water to drain out of the assembly.
So this shouldn't be too difficult to DIY. I'll document the process when I get around to doing it.
Nope. However, it only took them one day to get the parts in, including the countermeasure bump stoppers. It seems like these parts are available and all the dealers have to do is order them.bootymac wrote:Well, shit. I was going by the diagram and missed the text above it.
I had assumed that both versions sealed against the piston but after taking a closer look at Samir's photos ( http://www.kizashiclub.com/forum/viewto ... 895#p27895), it looks like the stock bump stops don't form a seal. This makes the DIY modification less ideal...
Did your dealer have the revised parts in stock? Looks like I'll be making some calls later
Aren't the shocks themselves cheaper on rockauto.com?bootymac wrote:Heard back from my dealer. $53 each and 3-4 days to arrive
Oddly enough, I placed the exact same order last night, from the same site. $30 each plus a total of $10 shipping. I decided to pass on the nut and bolt that Suzuki say to replace in the TSB, since that would have added $15 a side. Brushing them clean and adding a touch of blue thread locker for re-assembly should be fine (YMMV).Woodie wrote:I just ordered two of them for $70 delivered from suzukicarparts.com
Haven't received them yet, so maybe you might want to wait for a more complete story.
