Service Start System error on dash.
My Kizashi has done the same thing twice, during the most recent episode we never plugged anything into the usb port or power recepticles. The service adviser said that if it happens again, components in that circuit are going to need to be replaced until the problem is eliminated.
This sounds to be the most plausible explanation. Some OE component of the car is drawing more current than it should be. Then plugging in an accessory in sends that circuit over the top. The problem is not the accessory device. Sooner or later the OE device on the circuit, root of the problem, will completely fail...then they'll know. I have simultaneously had my Garmin plugged in to the outlet behind the center console flip cover and my cell phone charging from the outlet under the armrest numerous times with no ill-effects.Trailboss wrote:My Kizashi has done the same thing twice, during the most recent episode we never plugged anything into the usb port or power recepticles. The service adviser said that if it happens again, components in that circuit are going to need to be replaced until the problem is eliminated.
