Hi,
So I've spent a lot of time recently in the back of my car removing the tint glue off of my rear window.
In my time back there, I got suspicious that only the subwoofer on the rear deck was working. I know that the GTS and SLS models have the Rockford Fosgate sound system that is a 10 speaker system. As I count it, it's 1 on front dash, 2 on each front door (4 total), 1 on each rear door (2 total), and 3 on the rear deck including the subwoofer. I tested the rear speakers by the Fade function and turning the Bass to -6. There was almost no sound coming from the speaker covers on the rear deck. All the sound seem to come from the rear door speakers. I even crawled in the trunk and listened under the rear deck. I could even see light through the RH rear deck speaker cover. WTF!?
Anyone else notice anything strange about the rear deck speakers? Could mine be missing?
Do you think I should get this checked out with a warranty claim? I bought the car used with only 7500 miles on it. The sound system looks like it was not tampered with by the previous owner.
Rockford Fosgate rear deck speakers missing?
Ok, I resolved the issue.
I was under the assumption that there should be two speakers next to the subwoofer in the back. After looking it up in the service manual and online, it looks like there are no speakers back there. I was confused because then I only count 8 speakers, not 10.
I then came across this online and it solved everything: http://www.rockfordfosgate.com/(S(3j5ao ... x?id=12349
The speakers on the rear doors actually contain tweeters on them via a bridge. It's like a two in one speaker. The subwoofer is actually the only speaker on the rear deck of the car. There is nothing under those two long speaker covers in the rear deck on each side of the subwoofer.
As for the steel wool rusting: I don't think it will be an issue. It's not like it remains on the surface of the titanium and titanium does not rust.
Those two long "speaker covers" are most likely just vents for flow through ventilation and not speaker covers. Out of interest my non RF equipped Kizashi has all the wiring in place for the subwoofer etc, but they've gone to the trouble of spot welding a round piece of steel to fill in the subwoofer cut out in the chassis. I was thinking about maybe adding one later on down the track (with an amp etc). But I've already had one instance where a load would have fouled on the subwoofer if it was fitted, so am not so keen now.
Um, OK, believe whatever you like. Never mind the metallurgist telling you how it works.KuroNekko wrote:As for the steel wool rusting: I don't think it will be an issue. It's not like it remains on the surface of the titanium and titanium does not rust.
you remind me of someone I know.
