P0443 - Evaporative Emission Control System Purge Control Valve Circuit
Good Evening Fellow Kizashi -
I attempting to fix the check engine light for a P0443 - PCV Valve Circuit. Tried the replacement of the gas cap with no luck. I have a picture of what the PCV valve looks like from a diagram at Suzuki Parts.
http://oemsuzukiparts.com/parts/2012/SU ... am=1470215
Anyone have any luck repairing this themselves? If I can find it I can either replace it or check the wiring to it.
Thanks in advance,
First Time Kizzy Post
KCCO
2010 Kizashi Check Engine Light - P0443
The most important word in there is "circuit". That tells me that it's very likely a wiring problem. Every connector in line needs to be unplugged and plugged back up, and you need to check the sensor ground. One of those two wires almost certainly goes to ground, Suzuki's are famous for ground problems.
