Front Brakes
Replaced my front brake rotors and pads last spring and decided to take a look this fall to see how they were wearing. Also serviced the calipers. Unfortunately I did not pay attention to which slider pin went where. They're not the same and the maintenance manual does not indicate which goes left or right. One is longer than the other and the shorter one has a black rubber band towards the bottom of it. My brakes are wearing at an angle at both ends of the brakes pads on both sides of the rotor. Same for both front wheels. Did I put the slide pins the opposite of what they should have been or do I have a different problem?
