Hello everyone
I'm hoping someone can steer me in the direction to fault find my door issue on AWD .
When using remote,/fob , drivers door won't react, all other doors work. If i sit in vehicle and use the door lock/ unlock button....same same all but drivers door.
I can however lock and unlock via the key, and this also controls the other doors too.
I'm thinking the motor/solenoid in door, but am yet to remove door trim.
Thanks
Drivers door won't lock/unlock with fob
- SAEED_KIZZY
Did you check for blown fuses?
I suggest checking all fuses related to BCM and also the keyless module
- SAEED_KIZZY
yes,but sometimes lack of some power feed to BCM can cause strange things beside it's easy to check compared to the next stepsBrad20v wrote:No I have not yet , I would think it's more than a fuse, as the others all work.
Thanks
