Needing help
have a question about a 2010 suzuki kizashi does anyone know what this cable is called or where I can find one for my 2010 suzuki kizashi sls I've looked everywhere and can't find it at all I just need the whole cable because the one that came with the new valve body does not fit or doesn't even. Come close to matching, I mean the valve body is the right one but the cable is the wrong one. I put a picture to show what I'm talking about the black tip cord is the original one and the one I need but the white one Is the one that came with the valve body and the one that doesn't fit. What exactly is that. Cord/cable called anyone know?? I'll show some pictures to try and address what I mean...... So if anyone could point me in the right direction to where I could purchase the right cord / cable for the 2010 Suzuki kizashi SLS I would truly appreciate it because right now this is what standing between me and putting my car back together is obtaining the right cable. Thank you
- This picture is showing what the right cable looks like for my vehicle , it's the one on the left side coming out of the valve body.
- IMG_20210423_001504.jpg (75.99 KiB) Viewed 1375 times
You are needing the case harness that is specific to Kizashi and sx4 only. I have one here but can I ask how you came to need one? What symptoms and or codes are you addressing with changing the valve body ? Most importantly, what are your miles and what debris were found on the pan floor? Where are you ? Is your sls an awd ?
