Rear Caliper bracket pins
Posted: Fri Feb 11, 2022 11:36 pm
Has anyone ever pulled the pins on their rear brackets to clean them up and relube them?
I’m having issues with premature pad failure after around 40k kms. Caliper and pins seem fine. I pulled the pins as I did last time I changed the pads. But I noticed that one pin has factory grooves in it and the other is completely smooth. Not sure which order these go back in or if it even matters, or if this could be a reason for the premature failure?
Anyone have any insight on why the one pin had grooves and which one goes in which?
