Transmission issues and help with parts
Chad1155
I have a 2010 kizashi and want to replace the trans as the belt has let go on the one I have now. I have a replacement trans from an 11 but figured I would replace the belt in the trans before install but am have ing an issue finding one does anyone here have any idea where to look and also will I need to have the trans programmed or should I use old valve body ???? Thanks for any help
Where are you located? We have a resident professional mechanic Old Tech who is located in NW Pennsylvania.
Chad1155
KuroNekko wrote: Tue Oct 11, 2022 5:54 pm Where are you located? We have a resident professional mechanic Old Tech who is located in NW Pennsylvania.
I’m from northeast pa and help would be awesome
I can do anything needed with the JF011E transmission and have all needed parts in stock. Business ph is 814 683 4863. Give me a call.
