Once I removed the front bumper, my front parking sensors experienced an unexpected malfunction. Initially, they resumed functioning briefly, only to cease operating once more. I conducted a car diagnosis yesterday, which revealed the following fault codes:
B1851 - Front Parking Sensor Communication Bus Error
B1860 - Front Left Parking Sensor
B1861 - Front Center Left Parking Sensor
B1862 - Front Center Right Parking Sensor
Have any of you guys experienced these fault codes, and know a solution to the problem?
Front parking sensors wont work
- SAEED_KIZZY
parking sensor in Kizashi uses a simple 3-wire interface
1:GND
2:VCC(8V)
3:DATA pin
remove the bumper and check VCC and GND with multimeter. Here is the wiring diagram to diagnose. check YEL/RED, GRN/RED, BLUE/RED wire.
1:GND
2:VCC(8V)
3:DATA pin
Thank you so much! Where did you find this wiring diagram?SAEED_KIZZY wrote: ↑Fri Sep 15, 2023 8:38 pm parking sensor in Kizashi uses a simple 3-wire interface
1:GND
2:VCC(8V)
3:DATA pin
- SAEED_KIZZY
you can find it here
viewtopic.php?f=13&t=4786&start=10
