Steering wheel controls
c3hev88
So I have a 2013 suzuki kizashi sls and my steering wheel controls on the left side don't work (volume, mode button). I changed the steering wheel completely and it still does not work. Does anyone know what other solutions there is?
Sent from my SM-G965U1 using Tapatalk
c3hev88
c3hev88 wrote:So I have a 2013 suzuki kizashi sls and my steering wheel controls on the left side don't work (volume, mode button). I changed the steering wheel completely and it still does not work. Does anyone know what other solutions there is?
No one knows?
Did you check wiring and possible fuses? Maybe a loose harness?
c3hev88
KuroNekko wrote:Did you check wiring and possible fuses? Maybe a loose harness?
Is there a fuse for the steering wheel controls?
AirRideFan
How do you change the steering wheel in a Kizashi? Is it hard to remove / re-install?
2012 KIZASHI Sport SLS
AirRideFan wrote: Wed Jan 24, 2024 9:59 am How do you change the steering wheel in a Kizashi? Is it hard to remove / re-install?
you need a steering wheel puller and 2 long bolts bolted on your steering wheel and then with the help of a steering puller you can take it out.something like this
Above is the correct way. I cheat and just loosen nut 2 turns and place feet firmly on the floor and pull and wiggle steering wheel.
