2010 Kizashi Lifespan Questions
Sorry for the late reply but here it is:NickL wrote:If someone could share a link that would be really awesome...
https://allegro.pl/kategoria/czesci-sam ... t-1-2-1218
I don’t know if you can do some currency exchange or whatever to buy something from there, though.
Thanks a lot man!
I just realized that this guy is selling a Kizashi OEM radio for arround 75 bucks which is reasonable price. For example, somebody else in Germany is selling the same device and wants 270 dollars for it. The man is crazy!
Anyway, the only problem is that I don't understand polish language at all. Hopefully the seller speaks and writes English so that we could somehow communicate. Otherwise I am lost.
I looked around on the allegro site for a few minutes and couldn’t find a way to change it to English, although there is a small section in English like terms of service and a help center.NickL wrote:Anyway, the only problem is that I don't understand polish language at all. Hopefully the seller speaks and writes English so that we could somehow communicate. Otherwise I am lost.
There’s also an app, but it too is only in Polish. However, some of the reviews complained about the app not having an English option, and the developers said they are working on it (as of two months ago). So it sounds like it will happen eventually.
How far are you from Layland WV? There's a 2010 S for sale there, AT/AWD, 149,000 miles on it. The listing simply says "needs transmission". Assuming the transmission is, in fact, the only problem... ballpark cost to have it rebuilt or replaced? ... If that's a repair you still do and you're within 200 miles of Layland my AAA would tow it up there.old tech wrote: ↑Thu Dec 24, 2020 4:29 am These are rebuildable but should be approached a little differently. Changing fluid and cleaning pick up screen every 30k mile or more often and checking pan debris will help but the 6 balls in primary eventually will end up peeling and then breaking in half. At this point the primary is destroyed along with the belt and sometimes even the secondary. If driven until you notice some trouble, this is it most likely. If tackled when the balls start to peel or before, the balls can be traded out for long pins pretty easily. If a trans that had no symptoms and just the tranny was brought to me, I could do the conversion for like $150 but after it fails it would add $600 or more. A complete rebuild isn't needed unless it has over 180K or torn up.
Welcome TwoScoops !TwoScoops wrote: ↑Sat Apr 02, 2022 8:01 amHow far are you from Layland WV? There's a 2010 S for sale there, AT/AWD, 149,000 miles on it. The listing simply says "needs transmission". Assuming the transmission is, in fact, the only problem... ballpark cost to have it rebuilt or replaced? ... If that's a repair you still do and you're within 200 miles of Layland my AAA would tow it up there.old tech wrote: ↑Thu Dec 24, 2020 4:29 am These are rebuildable but should be approached a little differently. Changing fluid and cleaning pick up screen every 30k mile or more often and checking pan debris will help but the 6 balls in primary eventually will end up peeling and then breaking in half. At this point the primary is destroyed along with the belt and sometimes even the secondary. If driven until you notice some trouble, this is it most likely. If tackled when the balls start to peel or before, the balls can be traded out for long pins pretty easily. If a trans that had no symptoms and just the tranny was brought to me, I could do the conversion for like $150 but after it fails it would add $600 or more. A complete rebuild isn't needed unless it has over 180K or torn up.
Look around a little, either yesterday or the day before old tech posted prices, I think he said $2,000.
Here it is: https://kizashiclub.com/forum/viewtopic ... 616#p54616
Layland wv to Linesville Pa is 5 hrs. $1900 total before sales tax. If its here at 8am , Ill have you headed home next morning or earlier (I will have to clear schedule with a little advanced notice to do this). All JF011E Parts and specific needed Kizashi parts in stock. My message folder is full. I'll try to figure out how to empty it.
I'm in Rochester, NY and would make the drive to you. Have ~113k miles on mine, all stock and bought new myself in 2010. Had the fluid flushed and replaced twice with Suzuki OEM trans fluid at 70k and 90k. The filter and some other part too. It was whining a bit when after 30 min of driving back then but since the second flush at 90k all noises went away and it's been acting 100% normal except I think the rear struts are are shot.
Let me know the best way to reach you and I'll schedule an early summer visit.
2010 Kizashi GTS AWD
Hey old tech, you're very near Geopalooza, the annual get together of crazies like myself who own GEO Metros. It takes place on rt 33 near Pierpont, OH.
https://geometroforum.com/official-15th ... 62098.html
