below zero cold starts
well here we are about to have the coldest mornings since winter began.. go figure . since my car stays outside and I have to leave early in the morning for work.. any suggestions on the starting process.. I would hate to push that button and it doesn't do anything.
- Speed_Racer
Block heater?
If you have an automatic CVT, maybe remote start? My parents used to have one that would auto-start their car every few hours at night for a few minutes if the temperature got below a certain limit (like -10F).
I think for me I will set my alarm to wake me up a few times during the night to turn it over and run for about 10-15 minutes just to keep it some what warm. . my only option for now.
I don't see the point of any of that. If your battery is good, it should be able to handle the PA temps. I would say starting every few hours for only 10-15 minutes would not allow the battery enough time to fully charge and then you run the risk of not having enough juice in the morning when you really need it. Only in climates that have below zero averages do they use heaters.
I agree. A battery in good condition should start your car fine even in temperatures well below freezing. PA may be cold, but it's not cold enough to require significant measures to ensure cold starting.nytq wrote:I don't see the point of any of that. If your battery is good, it should be able to handle the PA temps. I would say starting every few hours for only 10-15 minutes would not allow the battery enough time to fully charge and then you run the risk of not having enough juice in the morning when you really need it. Only in climates that have below zero averages do they use heaters.
thanks guys. I will not do that then. I will just do the normal start in the morning . esp sunday morning that is suppose to be the worst of this cold snap..
X3KuroNekko wrote:I agree. A battery in good condition should start your car fine even in temperatures well below freezing. PA may be cold, but it's not cold enough to require significant measures to ensure cold starting.nytq wrote:I don't see the point of any of that. If your battery is good, it should be able to handle the PA temps. I would say starting every few hours for only 10-15 minutes would not allow the battery enough time to fully charge and then you run the risk of not having enough juice in the morning when you really need it. Only in climates that have below zero averages do they use heaters.
Ahh the good old days. I'm from Minnesota and had a '69 Plymouth Fury III. It would sit out all night in -20 degree cold. Go out in the morning for school or work and it would crank twice and fire up like it was a summer day.
By the way, as current goes through the battery when it's cold, it will start to warm. As it starts to warm, it will provide more amps. One of the reasons the car cranks faster after it has turned over a few times. That combined with all the moving parts loosing up as it tries to move oil the viscosity of honey...
2011 Kizashi SLS CVT (silver)
2005 Honda Odyssey
2005 Honda Odyssey
