New owner added! 2013 Kizashi
Endeavour1200
Hello guys, I bought a 2013 Suzuki Kizashi Manual, but it did not come with any owners manual. Id like to know the basic stuff, if you guys can help :) .
Stuff like how to set memory seats, or other basic info that I don't know. Please if you could help me to make this experience alot better!
I'm in india, and Indian cars were imported from Japan as a unit, so this is essentially a japanese spec. I don't know if it is SLS or GTS, as they were launched in USA. All I know about the spec is that it is a 2.4L (176hp) motor with Manual trans and 7 speakers (no bluetooth). I can provide any more info too.
I'd be grateful, thanks alot.
Tom Kizzie
Memory seat. Contact ON (dont need to start i from what i remember. Position seat according your wishes and hold the 1 or 2 or 3 button next to your seat for like 5 seconds. Now its stored.
kizashi 6mt black
Endeavour1200
@ Tom naah that dosent work. Tried pressing M and then number too but no beep heard
Tom Kizzie
1.Adjust the seat position as desired.
2) Within 5 seconds after pressing the memory button (4) or while pressing thebutton, press one of the position but-tons 1 – 3 (5). A buzzer will sound whenthe position has been succesfully programmed. Did you have your car on the e-brake..
kizashi 6mt black
Endeavour1200
Yes, parking brake was on but no beep was heard
Tom Kizzie
Late reply but does it work already? I just made 3 new presets yesterday by pussing the number and then the "m" i believe. I needed 1 full second between pussing the number and the "m".
kizashi 6mt black
Endeavour1200
Tom Kizzie wrote:Late reply but does it work already? I just made 3 new presets yesterday by pussing the number and then the "m" i believe. I needed 1 full second between pussing the number and the "m".
Thanks for the reply but it dosent work. I've tried many arrangements but couldn't get it work. My last resort was to get it checked by a mechanic. Did you long press or short press and was there a beep heard?
I just set a position to memory yesterday or so. Adjust the seat to your liking. Make sure the seat can be programmed in the current mode such as vehicle ON, engine OFF (the seat buttons will light up when it can be programmed). Hold down M then one of the numbers like 1. Hold both until you hear a beep.
Endeavour1200
KuroNekko wrote:I just set a position to memory yesterday or so. Adjust the seat to your liking. Make sure the seat can be programmed in the current mode such as vehicle ON, engine OFF (the seat buttons will light up when it can be programmed). Hold down M then one of the numbers like 1. Hold both until you hear a beep.
Yeah so the lights on the seat light up, the parking brake is on. For approximately how many seconds should I depress the button? About 5 seconds? I don't hear any beep so I'm doing something wrong. Anyway I can't get it to work so I guess I'll get it checked once and for all.
