Check Engine Light comes on for first time ever!
n8dogg
At 132,000 miles, my CEL came on for the first time ever! Can't ignore it, display turns Orange and blinks incessantly! I commute at night so this is very distracting. :shock: Also it disables cruise control, which I use fairly regularly on my 45 min highway commute. O2 sensor code. I reset the light and it came right back. I figure at this mileage I'll just replace both of them as it couldn't hurt. Hopefully that's all it is and no further damage is occurring like a Cat going out or something. Getting the NTK brand...found them on Rock Auto way cheaper than anywhere else. Threw in a set of Power Stop Z23 rear pads while I was at it...they're due to be replaced soon.
Still the most reliable, low maintenance car I've ever owned. :D
easy to chip Vivid Red w/25% window tint
Pirelli Cinturato P7 Plus II
Power Stop Rotors and Pads
135,xxx miles and still lovin it!
Endeavour1200
What codes did you car show? Mine shows P0037 and P0138.
n8dogg
Endeavour1200 wrote:What codes did you car show? Mine shows P0037 and P0138.
P0037 only.
Endeavour1200
P0037 only.
Did you order the sensor online or did you buy it offline? How much did you get it for?
n8dogg
I double checked my error code, it was actually P2237. At any rate, I purchased the new O2 sensors on RockAuto.com. At the time I purchased them they were listed at $98.79 for the downstream sensor (NTK 24815) and $146.79 for the upstream one (NTK 24801). The upstream sensor was listed considerably more everywhere else I could find it like $206 at Amazon, $356 at Oreilys and $425 at Autozone just to name a few.
n8dogg
O2 sensors arrived from two different warehouses. Completed the job yesterday. Easy Peasy. Trouble codes gone!
