When I'm holding the throttle steady, the rpms fluctuate alot. Like if I've held the throttle at 1500rpms, the rpm needle goes down to 1300, then to around 1650, then settles down to 1500, then after a few seconds down to 1300, 1650, 1500 and this cycle continues.
I'm not sure as to what the problem could be, throttle body was cleaned along with an oil change 10k kms ago, MAF is clean too I suppose. Engine was warm.
Car had a delayed throttle response because of a bad O2 sensor, O2 sensor is fixed but delay is still existent though not noticeable. I know my motor mounts are worn and the pressure plate is on its way out, but other than that, there is no other "problem" with the car.
Any help appreciated!
Problem with throttle (RPMs fluctuate)
Pressure plate? Do you mean the Clutch pressure plate? If you have a manual then the rpms are not fluctuating like that, the car would be jerking violently enough to give you whiplash.
Yes I mean clutch pressure plate, and yes I know it has nothing to do with this issue, but I stated it nonetheless.
I could try that, don't know about the fuel filter availability though
Yup, still does that. AC fan was off.
- SAEED_KIZZY
could be an electrical problem I am not sure but time for an oil change for sure.Endeavour1200 wrote: ↑Tue May 31, 2022 3:19 pm When I'm holding the throttle steady, the rpms fluctuate alot. Like if I've held the throttle at 1500rpms, the rpm needle goes down to 1300, then to around 1650, then settles down to 1500, then after a few seconds down to 1300, 1650, 1500 and this cycle continues.
