Need help with rear differential/transfer case oil change
The factory rear diff fill is almost certainly a break-in oil. This was very common practice for hypoid gears back in the day. I use Sta-Lube synthetic (CRC Industries) in the new zuks because a) I can get it at NAPA, b) my pump fits the bottle nicely c) the pump/bottle combo fits and operates well under the car with it on ramps/stands and d) as I recall it meets the specs I found somewhere.
The factory fill transfer case oil looked brand new at around 36,000 miles so I left it in.
What's the pump that you use look like? I know this isn't one of the places a normal funnel is going to work. :(
SamirD wrote:What's the pump that you use look like? I know this isn't one of the places a normal funnel is going to work. :(
This pump:
http://www.harborfreight.com/sta-lube-g ... 40714.html
(the short pieces of tube allow extension of suction side in to taller bottles)
and this oil in the SX4 and Kizashi rear diffs:
http://crcindustries.com/auto/?s=SL2482
I've used Sta-Lube's 75W-140 full syn in the D44 diffs of the Rubicon I had as well.
Thank you for the links! That pump is going to have to be added to my tool collection. :D
Best 7 or 8 bucks I've ever spent. It gets used a lot.
It will make a whole lot of things easier. 8-)
But what do you do to clean it so different fluids don't cross-contaminate?
I used to leave it sit a long while and gravity drain. Then run a pump or two of the new fluid through it in to my waste oil container before filling whatever and called it good. That was only an issue when I was swapping fluids in the Jeep (syncromesh in trans, ATF in the tcase and the Sta-lube in the diffs). I haven't done any power steering in a while, but, same deal gravity drain and a couple pumps of the new fluid to flush. I should have one pump for each type, but I don't.
Ronzuki wrote:I should have one pump for each type, but I don't.
That's what I'm going to do, especially as cheap as these are. 8-)
DWenz
Had what's left of the dealer do mine today (it's cold, it's close, and I'm feeling lazy). $90 and they used Mobil 1 for both... if anyone is wondering what they use at the dealer.
2013 SLS AWD
KansasKid
Bumping for awesome information about how cheap gear oil pumps are.
As long as I've had my Kizashi, I had been putting off the transfer oil/rear diff oil changes because I didn't want to take it to the dealer, and I didn't know the pumps were this cheap. Azumi just hit 40K, and I figured it is about time I stopped putting it off.
Don't get me wrong, I might still take it into the dealer, but I'm really really tempted try it myself now that my mechanic buddy is back from overseas for good.
