Does removing the air intake silencer actually make a difference in engine sound?
and how do you remove them?
Removing Air Intake Silencers
I wouldn't remove them. Engineers designed them specifically to account for pressure wave harmonics
http://www.ehow.com/info_12156112_air-i ... tml#page=0
http://www.brighthubengineering.com/mac ... fficiency/
i really do want to amplify the sound of my car though, i was thinking maybe a new Intake kit?
i just don't know where to look for one
I have had good experience with removing factory intake plumbing and changing to a K&N filter on many other cars. Every car is different, and the factory did have reasons for doing it that way. You could put in a K&N and remove some of the intake bits, and see how it is. If it gets a rasp at a certain RPM, or you pick up driveability problems, then just spend the 15 minutes and put it back on. I haven't really looked at it with this in mind, but I'm thinking that it might be creating a hot air intake off the radiator. That would be good for gas mileage in the winter, but bad for power.
RRM makes an intake kit, quite pricy though.
http://roadracemotorsports.com/store/in ... h=31_49_51
I had mine off for a long time, it sounded a bit better between 2500-3500 and sometimes below 2000 theres a bit of a grunty noise. I always intended on taking a video but I never got around to it. I ended up putting it back on because I had a feeling it affected my fuel consumption on long drives - not sure if it did or not and I wasn't sure if there were any negative effects and started to over think it bootymac may have just answered that for me.
I removed the front resonator, plugged it with a rubbed foot that happened to fit perfectly and sealed the edge with silicon to avoid sucking in any hot air.
2011 Premium Silver XL
