USB adapter for aftermarket radio CONFIRMED!
chase24870
Hey all,
Just did a head unit swap (JVC KW-V30BT ftw!) and in some of the threads I read there was some uncertainty as to which adapter is needed to use the factory USB port on aftermarket stereos. So, I took the plunge and bought one that a thread recommended but no one in the thread confirmed whether it worked or not. So, here I am to confirm that the Axxess subaru usb adapter (ax-subsub) DOES in fact work perfectly! Only thing I can say recommendations-wise, is during the install be very careful with that usb port (especially if you're in the CVT Kiz), because it can fall through its own hole under the console. I spent a pretty good while trying to get it out, and if I had just been more careful it wouldn't have fallen.
Anyways, here's a link to the adapter.
Thanks for reading!
Awesome! Thank you for sharing!
chazyouwin
Hi, I just bought this Axxess AX-SUBUSB piece. How does one install it? I took the USB collar off and the USB piece does not come out of the hole. Thought it would be easy to get out, plug it in and pull the old wire through. Nothing doing, at least not without insight.
