How to remove the drivers side interior door panel?
parrisjr
I am looking for someone who has removed the drivers side interior door panel. I want to remove the panel to repair a small dent in the middle of the door.
chevydually
FIRSET REMOVE SMALL PANEL BEHIND INNER DOOR HANDLE THER IS A SCREW THERE , ANOTHER SMALL PANEL IN ARM REST SCREW THERE AND THEN THE REST ARE DOOR PANEL TO BODY CLIPS START IN LOWER LEFT AND PRY OUTWARDS AND THEM DOOR PANEL OFF PANEL IN ARMREST JUST BEHIND THE WINDOW SWITCH PANEL
Try the list function next time. Caps are poor forum edict.
Thanks for helping out though.
parrisjr
Thanks "chevydually" I will give it a try next week. I have never had any luck with the panel to body clips. Usually end up breaking a few or ripping them out of the door panel itself.
KHCreason
you may want to invest in the proper tool, then, to prevent that from happening.
parrisjr
By the "proper" tool, I assume you mean a tool like a long handle screw driver with a forked tip?
chevydually
pocket srew driver or small plastic pry tool. sorry about caps forgot were on
KCKizashi
Here's a link to various sections of the service manual. How to remove the door panel and all screw and fastener locations identified.
http://www.kizashiclub.com/forum/viewto ... f=28&t=316
2010 Platinum Silver GTS AWD
