Inner tie rod news
Sorry suzukivarsi. I am out and dont plan on getting anymore. An inner tie rod for a 2012 Nissan Altima can be altered to fit the Kizashi. Also there are plenty of good used ones out there. i could sell you one but the aftermarket replacement Nissan option is probably cheaper and faster.
Obama_is_hot6
old tech wrote: Sat Jan 25, 2025 8:28 pm Sorry suzukivarsi. I am out and dont plan on getting anymore. An inner tie rod for a 2012 Nissan Altima can be altered to fit the Kizashi. Also there are plenty of good used ones out there. i could sell you one but the aftermarket replacement Nissan option is probably cheaper and faster.
what is the modification that you have to do to make it fit?
YUUUURT
The threaded stem potion is longer than the kizashi. it needs a bit cut off and then run a die down the stem.
I have just put an order in for 8 more. Vender says he can get me them. We will see. This could and usually does take 2 months or more. Ill post when i receive them.
As of 3/20/25 I now have 8 more of these high quality , made in Japan inner tie rods. These can be very hard to find and these look like the last ones I'll be able to get. $40 plus shipping if you need one.
Mirak
old tech wrote: Fri Mar 21, 2025 3:10 am As of 3/20/25 I now have 8 more of these high quality , made in Japan inner tie rods. These can be very hard to find and these look like the last ones I'll be able to get. $40 plus shipping if you need one.
Hi sir! Do you still have a pair of those tie rod i'll buy 🙏
I do. Ill pm you info.
