How to Polish Off Mild UV Damage from Headlights
Speed_Racer
LPSISRL wrote:I've got 70K miles on my 2011. For the last year it's been kept in a garage but that only helps a bit on weekends. It's outside all the work days in the Virginia sun. My headlights are as clear as the day the car was new.
Interesting. My situation is the opposite. I park in a covered garage during work hours. It's parked outside otherwise. I also think the orientation of the vehicle in relation to the sun is a huge factor. My headlights directly face the sun as it's parked towards the south, maximizing exposure to the sun's rays.
It's obvious what you need...
There is someone in my neighborhood that used to have these on their SUV. They are the feminine counterpart to truck nutz in purpose.
Recently, I had to revisit headlight polishing as the UV damage got worse on my headlights. It's an inevitable aspect of plastic headlights on cars that are often parked outdoors during the daytime. It just happens with time. While my headlights never got too bad (due to regular light polishing at car washes), the damage seemed to get worse between the treatments given the age of the vehicle and constant exposure to the California sun as my vehicle is now always parked outdoors with little or no shade.
Below is a picture of the headlight prior to any treatment.
I decided to do a combination of procedures utilizing products from both Meguair's and 3M. Some of the materials were sourced from kits I've used on other cars while others were separately purchased products.
Below are all the materials I used.
- A cordless drill
- A velcro drill adapter to mount pads and discs (included in a 3M headlight polishing kit)
- A foam polishing pad (included in a 3M headlight polishing kit)
- A 3M Trizact 3000 grit sanding disc (included in a 3M headlight polishing kit)
- 3M's Headlight Renewal polish
- Meguiar's Headlight Protectant
- Meguiar's Headlight Coating spray
- Microfiber polishing pad
- Terry cloth polishing pad
- Microfiber towels (for wiping off all products after each application)
- Masking tape
The first step is to wash the headlights thoroughly to get them clean. After drying, I masked up all areas around the headlight to protect the finish from polishing, residue, and over-spray.
The first step was using the 3M Trizact 3000 grit disc with the drill. The Trizact pad is a very very fine abrasive pad that has a chalky texture. I used a combination of low speed and high speed polishing after wetting the headlight and the disc. As it polishes, it leaves a light milky residue which is normal. Given the rather light oxidation and UV damage on my headlights, I needed something just a bit more abrasive than a polish in paste form for the initial step. This pad was the answer.
After the Trizact pad, I used the 3M Headlight Polish which I find more effective than Meguiar's PlastX which I've used in the past. I first put the polish on the orange foam pad and polished the headlight with the drill on low speed. After a thorough polishing, I wiped off the residue and repeated it 2 more times to thoroughly polish the headlight. It's this process and product that really removes the damage from lightly oxidized headlights and restores clarity.
After the drill process, I used the 3M Headlight Polish again but manually with a microfiber pad to get into areas harder to reach with the drill pad. I also used a vertical and horizontal polishing movement unlike the drill's circular movement. After that was done, I wiped it off and buffed.
The next step was with the Meguiar's Headlight Protectant. This is essentially like a wax treatment for headlights whereas the previous product was the actual polish that removes the oxidation. I've used the Protectant in the past, but much like wax, it needs frequent re-application for it to be effective protection. The Protectant is applied by hand much like wax and then wiped off. I used the terry cloth polishing pad for this process.
The last step and the only new one for me this time was the application of Meguiar's Headlight Coating which is a spray. This is a product I hadn't seen until recently in stores. Other forum members here also have tried it (or similar products) and claimed it was a game-changer in clarity restoration and long term protection so I felt like this was the missing link I was looking for to really get that protective seal. It's essentially like a UV-blocking clear coat.
Per the instructions, I sprayed a first layer and let it dry 5 minutes. After the first coating, it had an immediate effect in greatly enhancing the clarity of the headlight to almost like-new condition. While the polish took out nearly all the oxidation and UV damage, this coating spray enhanced the clarity. On a side note, it also smells wonderful which is something I find with many Meguiar's products. They honestly should get into automotive air fresheners because their waxes, polishes, and sprays often smell much better than air fresheners currently available.
After the initial coating dried, I sprayed a 2nd coating and waited 5 minutes. By this time, the headlights looked almost new with amazing clarity.
The next and last step is where I went wrong. I got overly ambitious with the impressive clarity of the Headlight Coating spray and decided to give the headlights a lighter 3rd coating after the 2nd dried completely. Unfortunately, it proved to be too much and actually made the headlights a little opaque (as in a bit greasy) from the near perfect clarity of the 2nd coating. I did it as an extra protective layer given the brutal California sun and heat, but now I see why the instructions only suggest 2 coats. A 3rd is too much. Oops. While the headlights are far from ruined or blurry and certainly in better shape than prior to treatment, my warning is not to do a 3rd coating like I did. It's too much. Lesson learned. I'm not too worried as the coating isn't permanent and I can do it right the next time when the coating inevitably wears off over time and the headlights need treatment again. I'm just hoping it's a good while from now as Meguair's claims the Headlight Coating lasts up to a year.
Overall, the process and the materials yielded excellent results and restored the headlights to like-new condition. Again, just don't do more than 2 sprays with the Meguair's Headlight Coating as a 3rd just makes it look greasy. Hopefully, this product is the key to keeping the headlights clear over time.
Now some before and after photos:
Before:
After:
Nice write-up Kuro. That last pic really shows the improvement clearly. Is that a final pic, or had you not applied the last step in your process? My lights aren't as bad as yours are, however, they are deteriorating rather quickly. Noticed a drastic change through-out this past summer.
Ronzuki wrote:Nice write-up Kuro. That last pic really shows the improvement clearly. Is that a final pic, or had you not applied the last step in your process? My lights aren't as bad as yours are, however, they are deteriorating rather quickly. Noticed a drastic change through-out this past summer.
The "After" pictures (including the last one) were taken after the complete process including the 3rd spray of the Headlight Coating. As you can see, the polishing had great effect and the Headlight Coating improved the clarity. It really made minor imperfections just disappear with the spray much like what the others reported. It's just that the 3rd coating made the headlights a bit greasy-looking compared to the impressive clarity of the 2nd coating. I wanted to relay this finding so people don't make the mistake I did.
From this experience and that of previous ones too, I'm no longer worried about getting deteriorating headlights back to great condition as I think I got that process down. It's now more about what's going to make the clarity last. I'll update this thread over time with photos but I'm optimistic about Meguair's Headlight Coating.
Update:
It's been about a month and a half since the treatment and the headlights looks noticeably more clear than they would otherwise. This is especially the case given I always park outdoors.
I'll update again with pictures at a later time.
Great writeup as usual. And timely too as our SLS twin of yours is starting to show some hazing now after being back in Alabama outside. It has had the luxury of being in climate controlled garages until this point.
How well as the Meguiars Protectant held up over time?
Firefly
Thanks for the great writeup.
UV haze on older cars is such a sad, inevitable sign of age.
The appearance reminds me of an old person's toenails.
The headlights are now pretty tinted with a yellow hue but not hazy/cloudy like many hazed headlights. They definitely need polishing but they still remain somewhat clear in terms of opacity, but yellowish.
Overall, the treatment did help, but it doesn't last forever. I plan to wash my car soon and polish the headlights up.
Once I'm out of my current products, I'll get the product below. I used it on a co-worker's 4Runner and observed the best results of any headlight restoration product I've ever used.
Thank you for the update! Meguiars makes some great stuff. I was able to attend their detailing clinic once on a road trip from CA to AL and learned a tremendous amount about detailing and their products. My brother's car also gave them a new 'world's dirtiest clay bar' for them to show to other classes. :oops:
