sound system
paininthenuts
I have the sport, and wondered what anyone knows about the sound system. That's to say who makes it, and what watts per channel etc. I believe there are 4 complete speakers, 2 separate woofers and 2 separate tweeters, and it sounds amazing. Any other info would be appreciated
Cheers
Do you have the Rockford Fosgate system?
If so, here's some info:
http://www.rockfordfosgate.com/products ... 13-kizashi
paininthenuts
How would I know, there is nothing written on the system to indicate anything. I am supposing though, that this system must be standard on the sport, as it sounds amazing
I'm not sure if the UK models got the RF stereo. It should say on the head unit by the screen.
You can also check by opening the trunk and looking for the subwoofer on the rear deck. The subwoofer has a back cover that has Rockford Fosgate written on it.
These are the speakers that comprise the RF system in the Kizashi:
BxKizashiS
paininthenuts wrote:How would I know, there is nothing written on the system to indicate anything. I am supposing though, that this system must be standard on the sport, as it sounds amazing
Yeah you probably have the standard radio than, not the Rockford Fosgate system. Just like me... Just (4) 6.5" door speakers (1) 3" center speaker and (2) 1" tweeters on the front doors... I removed everything and upgrade all my speakers to midranges, Even customed installed (2) 6x9's in the rear deck... The factory was pretty nice but i like to go loud with hard bass lol
2012 Suzuki Kizashi S AWD
Facebook.com/jpreludesi
IG: N2OKizashi
You'd know if you have the RF as there are logos not only on the bottom of the sub, but the top, and the door grilles as well.
paininthenuts
Thanks for your replies. It would appear I have the standard system. That said, I am not disappointed, as it is the best sound system I have ever had in a car, including my Merc E Class.
AirRideFan
Yooo...I'm in the process of figuring out what speakers to replace my factory door and tweeters with in my RF-equipped Kizash SLS. I'm going to run them off the factory Rockford amp- just looking to enhance my 60Hz-1000Hz, mainly.
Removed the factory sub and making that a port to the new sub setup. Can't wait to hear it when it's all done.
BxKizashiS, do you have any pics of yours? I'd love to see it! And your IG account doesn't seem to be correct- I tried it, no go!
Let me know... Thanks dude
2012 KIZASHI Sport SLS
Drem
Just a note you may be interested in. The factory RF speakers, at least the door mids, are only 2 ohm speakers. The industry standard is 4 ohm so you'll only draw half the power from the factory setup with most aftermarket speakers. My setup is completely aftermarket, I can show you pics of the removed RF speakers in the morning when I go home.
AirRideFan
Drem wrote:Just a note you may be interested in. The factory RF speakers, at least the door mids, are only 2 ohm speakers. The industry standard is 4 ohm so you'll only draw half the power from the factory setup with most aftermarket speakers. My setup is completely aftermarket, I can show you pics of the removed RF speakers in the morning when I go home.
Ahh...that def helps me out! Thanks so much. I guess I'd have to find aftermarket 2ohm mids and coaxials... if that's even possible, to make the best of it via the RF amp. I wonder how the power is split up--- does anybody have any idea approx. how many watts are going to each of the 8 channels?
I'm totally just guessing here, but thinking.... it's probably something around 75w into each of the front doors mids and tweeters, 25w to the front center channel in the dash, maybe 50w to the coaxials in the rear doors and 150w to the Dual Voice Coil 8" Rockford Sub?
